twicer ®   27-Apr-2021 18:41
Lessons Learnt | Wet Damage to Cargo of Maize
Year: 2021
Publisher: UK P&I Club
Playtime: 04:21
Quality: HD
Format: MP4
Video: 1920x1080 H.264 MPEG-4 AVC
Audio: AAC, 44 KHz x 32
Description: UK P&I Club has launched its latest video in a series of award-winning reflective learning training videos, based on a real-life case of a vessel which incurred significant damage to its maize cargo due to a failure to conduct basic checks upon completion of loading.
The animated video depicts an incident where a bulk carrier is fixed to load a full cargo of yellow maize in bulk; the previous cargo had been bulk fertiliser. On completion of loading, all five holds were fumigated and the holds were then closed, secured and sealed. During the initial stages of the voyage, the vessel encountered heavy weather, with spray and seas shipped on deck and all hatches covered over a period of eight days.
The series of videos provide an interactive training experience with a focus on educating crew members on common marine accidents or oversights and how to mitigate the risk of them occurring. Hosted across Thomas Miller websites, the videos are available to view for training purposes by both marine employers and their employees.
Lessons Learned:
• The thorough removal of cargo residues from cross joints, coamings, seals, drainage channels and drains upon completion of loading is of paramount importance to maintain the weather-tight integrity of the cargo hold hatch covers.
• A responsible crew member should be assigned to check that cleaning of the joints, seals and channels is done properly before the hatch covers are closed and secured.
• These checks should be incorporated into the vessel SMS pre-departure cargo-worthiness check lists.
end
Text
The subject 5 hold vessel was fixed to load a full cargo of yellow Maize in bulk. The previous cargo was bulk fertiliser. On completion of loading, all holds were fumigated and the holds were then closed, secured and sealed.
During the initial stages of the voyage, the vessel encountered heavy weather, with spray and seas shipped on deck and all hatch covers over a period of 8 days.
Upon arrival at the discharge port, the hold and manhole seals were inspected and found to be intact. Hold no.'s 2, 3 and 5 were approved for discharge. However, hold no.'s 1 and 4 were rejected. A bad odour was reported at the forward end of both hatchways.
The surface of the cargo stow in both of the rejected cargo holds was found to be locally mouldy, discoloured and caked, with temperatures in the affected areas measured up to 63°C. The quantity of damaged cargo was estimated to be about 10 to 12 MT in each hold.
During the pre-discharge inspection of the cargo, examination of the hatch cover panel cross joints of hold no.'s 1 and 4 revealed that a substantial amount of wetted maize kernels and associated residue were present in the drain channels above and between the cross joint sealing. It was apparent that the panel cross joints had not been cleaned in preparation of the hatch covers being closed at the load port. The hatch coaming drain channels were also found to contain cargo residue, which had either not been removed after loading or had collected in the channels through water drainage from the cross joints.
Lessons Learnt_Wet damage to cgo of maize.mp4
Download [35 KB]
Lessons Learnt | Collision with a Fishing Vessel [2018, MP4]
Lessons Learnt | Collision When Overtaking [2019, MP4]
Lessons Learnt | Serious Injury to Pilot [2020, MP4]
Lessons Learnt | Serious Eye injury During maintenance of Fresh Water Steriliser [2021, MP4]
Lessons Learnt | Burn Injury to Engineer [2021, MP4]
Lessons Learnt | Fall in Cargo Hold [2021, MP4]
Lessons Learnt | Mooring Injury [2020, MP4]
’Inside Ship’ video series [2020-2021, MP4]
BSafe: Incident Case Study No.24 (August) - Britannia P&I Club [2024, PDF]
BSafe: Incident Case Studies Nos 13-16 - Britannia P&I Club [2022, PDF]
The time now is: Today 23:27
