NNT ®   20-Mar-2015 08:56
UFC Design: Moorings
Year: 2012
Author: HQUSACE,NAVFAC,AFCEE
Genre: Reference book
Publisher: U.S. Army Corps of Engineers,Naval Facilities Engineering Command, Air Force Center for Engineering and the Environment
Edition: 1 September 2012
Pages count: 208
Description: The Unified Facilities Criteria (UFC) system is prescribed by MIL-STD 3007 and provides planning, design, construction, sustainment, restoration, and modernization criteria, and applies to the Military Departments, the Defense Agencies, and the DoD Field Activities in accordance with USD (AT&L) Memorandum dated 29 May 2002. UFC will be used for all DoD projects and work for other customers where appropriate. All construction outside of the United States is also governed by Status of Forces Agreements (SOFA), Host Nation Funded Construction Agreements (HNFA), and in some instances, Bilateral Infrastructure Agreements (BIA.)
Therefore, the acquisition team must ensure compliance with the most stringent of the UFC, the SOFA, the HNFA, and the BIA, as applicable.
The UFC 4-159-03, DESIGN: MOORING represents another step in the joint Services effort to bring uniformity to the planning, design and construction of piers and wharves. This UFC contains extensive modifications in the following areas:
- Heavy Weather Mooring
- Passing Ship Effects
- Ship Generated Waves
- Conversion from Mil-Hdbk to UFC and general updates and revisions
UFC_Design_Mooring_2012
Guadalcanal: The First Offensive - John Miller [2005, PDF]
Design of Marine Facilities: Engineering for Port and Harbor Structures - John W. Gaythwaite [2016,…
From the Sea to the Stars - A Chronicle of the US Navy’s Space and Space-related Activities,…
Design of Marine Facilites for Berthing, Mooring and Repair of Vessel (2nd Ed) - John W. Goythwoite…
Maritime works. Code of practice for design of fendering and mooring systems - Technical Committee…
The Impact of Design to Cost on Naval Ship Design - Michael Nickelsburg [1975, PDF]
Environmental aspects of dredging - R. N. Bray [2008, PDF]
Planning And Design Guidelines For Small Craft Harbors - ASCE [2012, PDF]
Guidance for safe return to port projects - DNVGL [2016, PDF]
Code of Practice for Marine and Cranes - Jari Ylitalo [2012, PDF]
The time now is: Today 17:44
