zmhljj10 ®   02-Jan-2018 14:40
Guidance for safe return to port projects
Year: 2016
Author: DNVGL
Pages count: 21
Description: DNV GL class guidelines contain methods, technical requirements, principles and acceptance criteria related to classed objects as referred to from the rules.
Changes – current.................................................................................................. 3
Section 1 General.................................................................................................... 5
1 Introduction.........................................................................................5
2 Background..........................................................................................5
3 Application........................................................................................... 5
4 Definitions and abbreviations.............................................................. 6
5 Regulations and reference documents.................................................6
Section 2 Safe return to port – intentions.............................................................. 7
1 Intentions............................................................................................ 7
2 Functional requirements...................................................................... 7
3 Restoration of capabilities after a casualty..........................................8
Section 3 Work process.......................................................................................... 9
1 General................................................................................................ 9
2 Early phase activities.........................................................................10
3 Multi-disciplinary work process......................................................... 11
4 SRtP test strategy............................................................................. 11
5 Assessments...................................................................................... 12
6 Documentation and approval............................................................. 13
7 On-board documentation................................................................... 14
Appendix A Expected contents of a Ship description / design philosophy............. 15
1 Ship's description.............................................................................. 15
Appendix B Expected contents of a System design philosophy / concept..............16
1 SRTP system concept - xx................................................................. 16
Appendix C Expected contents of a system assessment........................................17
1 SRTP system assessment...................................................................17
Appendix D Documentation timeline..................................................................... 19
1 SRtP documentation.......................................................................... 19
Changes – historic................................................................................................ 20
DNVGL-srtp
Download [721 B]
DNVGL - Liquefied gas carriers with spherical tanks of type B - DNVGL [2018, PDF]
Guideline for Cyber Secure - DNV [2021, PDF]
Buckling - DNV [2021, PDF]
Wave loads - DNV GL [2018, PDF]
Hull Structural Design - DET NORSKE VERITAS AS [2016, PDF]
Port State Control Committee Instruction 51/2018/06 Definitions and Abbreviations - Paris MoU on PSC...
Bulk Carriers – Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2007, PDF]
Guidelines for Cyber Resilience of Ships - ClassNK [2024, PDF]
The time now is: Today 23:32
