paolina_3 ®   16-Mar-2021 15:41
Rigging Service Guidelines
Year: 20XX
Author: Navtec
Publisher: Navtec
Pages count: 12
Description: This booklet is focused on the basic principles, surveying, maintenance, and life expectancy of both rod and wire rigging of yachts. The importance of routine maintenance is critical, and a well maintained yacht is defined by the amount of time and effort spent on the care and monitoring of its systems, mast and its associated rigging components in particular. For cruising and racing yachts performance, reliability and safety depend on routine mast and rigging inspection schedules. This guidelines should help define rod, wire and fiber rigging life expectancy, help to outline and create a service schedule and answer some general questions regarding rod, wire and fiber cable maintenance.
Introduction
Rod Rigging Life Expectancy
What to look for when inspecting rod rigging
Wire Rigging Life Expectancy
Fiber Rigging Life Expectancy
Yacht Displacement Classifications
Recommended Maintenance Inspections
Mast System Inspection Categories
Recommended Maintenance Intervals
Maintenance Authentication
General Information
Rigging Service Guidelines.pdf
Download [1 KB]
Guide for judging condition of relevant piston-running components Liners, Pistons and Piston Rings, ...
The Boatyard Book - A boatowner’s guide to yacht maintenance, repair and refitting - Jollands S. [20...
Rigging Techniques, Procedures, and Applications - Department of the army [2001, PDF]
Ocean Sailing - Robert James [1980, PDF]
Wire And Fiber Rope And Rigging - Naval Sea Systems Command [1999, PDF]
Calibration Principles, Chapter 1 - Unknown [2012, PDF]
Rigging: Everything You Always Wanted to Know about the Ropes and the Rigging, the Winches and the M...
Guidance Notes on Maintenance and Repair of Protective Coatings - ABS [2017, PDF]
Selecting Materials For Sea Water System - B. TODD, [1999, PDF]
OCIMF Guidelines for STS hoses - OCIMF [2021, PDF]
The time now is: Today 03:46
