skipper3362 ®   11-Feb-2021 21:35
Coatings: Materials, Processes, Characterization and Optimization
Year: 2021
Author: Kaushik Kumar , B. Sridhar Babu , J Paulo Davim
Publisher: springer
Edition: 1st
ISBN: 978-3-030-62163-6
Pages count: 189
Description: This book presents recent developments in the coating processes, sub processes and emphasizes on processes with the potential to improve performance quality and reproducibility. The book demonstrates how application methods, environmental factors, and chemical interactions affect each surface coating's performance.
In addition, it provides analysis of latest polymers, carbon resins, high-temperature materials used for coatings and describes the development, chemical and physical properties, synthesis, polymerization, commercial uses and characteristics for each raw material and coating. Characterization techniques to solve the coating problems are also presented, as well as optimization studies to identify the critical coating parameters to ensure a robust process.
Welding Technology - J. Paulo Davim [2021, PDF]
Advanced Welding Engineering and Technology for Marine Applications - Kaushik Kumar and Others [2026...
Marine and Offshore Corrosion - Kenneth A. Chandler [1985, PDF]
Modern Mechanical Engineering: Research, Development and Education - J. Paulo Davim [2014, PDF]
High Temperature Corrosion and Protection of Materials 7 (Volume 1) - Pierre Steinmetz, Ian G. Wrigh...
Corrosion of Constructional Steels in Marine and Industrial Environment - J.K.Saha [2013, PDF]
Friction Stir Welding and Processing IX - Yuri Hovanski [2017, PDF]
Application of Clean Fuels in Combustion Engines - Gabriele Di Blasio · Avinash Kumar Agarwal Giacom...
Valves, Piping and Pipelines Handbook - T.Dickenson [1999, PDF]
Stratosphere Troposphere Interactions An Introduction - K. Mohanakumar [2008, PDF]
  • Topic closed
The time now is: Today 03:33
