SerTan ®   21-Dec-2016 15:13
Corrosion of Constructional Steels in Marine and Industrial Environment
Year: 2013
Author: J.K.Saha
Genre: Technical book
Publisher: Springer
ISBN: 978-81-322-0720-7
Pages count: 187
Description: Frontier Work in Atmospheric Corrosion.
The book entails investigative methods for better understanding of the degradation process and uses of high performance paints formulation and also compares them on mild steel (MS) and weathering steel (WS) through various AC/DC electrochemical test methods and surface characterization through electron microscopy, XRD and Raman spectroscopy. This book also deals with the corrosion studies undertaken considering three phases (solid, liquid and gas) with latest techniques and the emphasis has also been given on degradation of materials due to atmospheric corrosion as this is of immense interest to present engineers and researchers.
Corrosion of Constructional Steels in Marine and Industrial Environment(Springer 2013).pdf
Download [7 KB]
Developments In Marine Corrosion - Campbell S.A. at all [1998, PDF]
Coatings: Materials, Processes, Characterization and Optimization - Kaushik Kumar , B. Sridhar Babu…
Marine Corrosion of Steels - Chao Liu, Bingqin Wang & Xiaogang Li [2026, PDF]
Corrosion and Protection of Marine Engineering Materials - Yanhua LEI (Edit [2023, PDF]
Friction Stir Welding and Processing XI - Yuri Hovanski · Yutaka Sato · Piyush Upadhyay , Anton A.…
Water in Lithium-Ion Batteries - Futoshi Matsumoto, Takao Gunji [2022, EPUB]
Risk-Based Ship Design - Methods, Tools and Applications - Apostolos Papanikolaou [2009, PDF]
High Temperature Corrosion and Protection of Materials 7 (Volume 1) - Pierre Steinmetz, Ian G.…
Marine Corrosion of Stainless Steels - Chlorination and Microbial Effects - Working Party on Marine…
Corrosion Mechanisms in Theory and Practice - Philippe Marcus [2012, PDF]
The time now is: Today 16:01
