SerTan ®   02-Jan-2019 01:41
Common Structural Rules for Double Hull Oil Tankers
Year: 2004
Author: ABS + DNV + Lloyd's Register
Genre: Convention (rules)
Publisher: ABS + DNV + Lloyd's Register
Pages count: 588
Description: Three Classification Societies formally agreed in early 2002 to commence a major project to jointly develop a single set of Classification Rules and Procedures for the hull structureof oil tankers. One of the principle objectives in achieving the overall goal was to develop a set ofcommon Rules that would avoid the possible competition between Classification Societies on the minimum safety standards.
Since that decision, the three Classification Societies have combined their unique experienceand expertise to produce a set of Common Structural Rules for Double Hull Oil Tankers of length equal to or greater than 150 metres and such Rules are presented in this document. It is to be particularly noted that in developing these Rules due cognizance has been taken of ensuring that the overall safety of the hull structure is equivalent or better than existing design criteria, has sufficient durability in terms of corrosion margin and fatigue strength, and the need to transparently define the relationship between required scantlings for design and those for renewal.
Common Structural Rules for Double hull oil Tankers.pdf
Download [13 KB]
Design and Operations of Double Hull Tankers - RINA [2004, PDF]
BV - Rules for the Classification of Steel Ships - PART B – Hull and Stability -2021 - BUREAU…
General Information for the Rules and Regulations for the Classification of Ships - Lloyd’s…
Guidance Manual for Tanker Structures, 2024 Consolidated Edition - Witherby / Tanker Structure…
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS 2014 [2014, PDF]
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS [2022, PDF]
Determination of structural capacity by non-linear finite element analysis methods DNVGL-RP-C208 -…
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS [2025, PDF]
Guide for Alternative Requirements for Hull Construction of Vessels Intended to Carry Vehicles (130…
The time now is: Today 16:22
