Sanek89 ®   22-Oct-2020 23:55
Ballast Water Treatment System (Trojan marinex)
Year: 2017
Author: Trojan marinex
Genre: Instruction
Number of pages: 399
Description: General Description
Specifically designed for the marine environment, the Trojan Marinex BWT is unique, integrating two treatment processes, filtration and UV disinfection in one single unit.
With a small footprint, lower power draw, and minimum pressure loss, the system is well suited to both newbuild and retrofit installations. With a wide operational range, the system performance is not impacted by temperature or salinity.
Operation is fully-automated and can be controlled through the ship’s automation system, or through a touchscreen interface provided with the system.
During ballasting operations, water is treated with filtration and UV. During deballasting operations, water is only treated with UV.The Trojan Marinex BWT consists of the following principal components;
Treatment Unit
• TrojanUV Solo Lamp™ Technology
• Custom-designed Trojan Marinex filtration system
• Automatic lamp cleaning system to ensure maximum UV output
• Automatic drain and fill system to inhibit corrosion of wetted components
• Junction box for all cable and control connections
TABLE OF CONTENTS
DEVICE LIST
Trojan Marinex™ BWT - Device List
TECHNICAL OVERVIEW
Technical Specification - Trojan Marinex BWT
Technical Data Sheet
P&ID - MX0303
ELECTRICAL DRAWINGS
Wire Diagram Overview - MX0305
Wire Diagram Interconnect - MX0306
Wire Diagram Power Distribution Cabinet - 507585G
Power Distribution Cabinet Assembly - 507587G
Control Cabinet Assembly - 507581G Wire Diagram Control Cabinet - 507579
Junction Box Assembly - 507885G
MANUFACTURER’S MANUALS
Trojan Marinex BWT - Operation and Maintenance Manual
Process Master FEP300 Electromagnetic Flowmeter
Bray Controls - Operation and Maintenance Manual - Resilient Seated Butterfly Valves
Bray - Operation and Maintenance Manual - Series 6A Electro-Pneumatic Positioner
Bray - Operation and Maintenance Manual - Series 92/93 Pneumatic Actuator
Drain Pump Service Manual
CERTIFICATES
DNV Type Approval Certificate - Trojan Marinex
DNV Type Approval Certificate - Flow Transmitter
Download [4 KB]
Ballast Water Treatment System Erma First Manual - Manual [2019, PDF]
Crude oil tanker "British Kestrel" Cargo operating manual - Worldwide Marine Technology…
The time now is: Today 15:02
