marlamamba ®   17-Mar-2019 22:32
Rickmers Standard for Stowage and Securing of Project Cargo
Year: 2009
Author: Rickmers-Linie GmbH & Cie. KG (Hamburg)
Publisher: Rickmers-Linie GmbH & Cie. KG (Hamburg)
Edition: 4th
Pages count: 102
Description: This Rickmers Standard is considered the main reference for planning, handling, stowage and securing/lashing of project cargo in general. It applies to all vessels chartered and/or owned by Rickmers-Linie.
The spirit and purpose of this Standard is to inform shippers of cargo units, stevedores and supercargoes etc. about cargo handling and securing practices on board of the vessels sailing for Rickmers-Linie and to provide a specific update to masters and officers.
Realizing that safety requirements do not necessarily contradict commercial aspects, the main objective of Rickmers-Linie is to increase the technical and commercial performance of marine transport by avoiding damage and loss of cargo, finally resulting in an improved safety at sea and protection of the marine environment.
The Standard, in particular, provides detailed information about lifting, bedding and securing/lashing of cargo as well as the equipment used and its maintenance.
The Standard further describes the cargo information to be supplied by shippers in accordance with Chapter VI, Regulation 2 of the SOLAS-Convention (see Ch 1.3) and the necessary configuration of lifting provisions, bedding areas and securing points. The desired securing point configuration and lashing scheme of the cargo corresponds with the tensile strength (MSL as per IMO) of the fixed and loose securing gear on board of the vessels and their deck lay-out.
Additional info: New 2009 Edition revised and updated by Peter van den Berg (Rickmers-Linie) in November 2009
Rickmers Standard for Stowage and Securing of Project Cargo.pdf
Download [5 KB]
Rickmers Standard for Stowage and Securing of Project Cargo - Rickmers-Linie GmbH & Cie. KG…
Standard for Stowage and Securing of Project Cargo - Piter van den Berg [2009, PDF]
Guideline for Safe Solution for Project Cargo Operations - BBC Chartering & Logistic GmbH [2009,…
Guide for Fire-Fighting Systems for Cargo Areas of Container Carriers October 2019 - ABS [2019, PDF]
Unified Requirements on Preventing the Loss of Seaborne Containers - IACS [2024, PDF]
SOLAS Requirements and Implementation of the Amendments to SOLAS Regulation V/23 - IMO, IMPA [2025,…
Anchoring systems and Procedures - OCIMF [2010, PDF]
Guide for Fire-Fighting Systems for Cargo Areas of Container Carriers - ABS [2021, PDF]
Marine Guidance Note MGN 621 (M+F), Roll-on/Roll-off Ships -Guidance for the Stowage and Securing…
On board Maintenance and Drills agenda (updated) - Dromon [2022, PDF]
The time now is: Today 14:12
