virtual ®   26-Apr-2020 12:44
Furuno Operator's Manual Satellite Compass Model SC-70, SC-130
Year: 2020
Author: Furuno
Pages count: 141
Description: The SC-70/SC-130 is a new Satellite Compass™ designed with FURUNO advanced GPS kinematic technology. This compass has a wide range of applications for both land and sea vessels.
The main features are:
• Meets the requirement for the following regulations: IMO MSC. 116(73), ISO 22090 Ed 2.0, IMO A. 694(17), IEC 60945, ISO 22090 Ed 2.0, IEC 61108-1 Ed 2.0, ISO 20672 Ed 1.0, IEC 61924-2 Ed 1.0, IEC 61162-1 Ed 4.0, IEC 61162-2 Ed 1.0, IEC 61162-450 Ed 1.0, IEC 62288 Ed 2.0, IEC 61924-2 Ed 1.0 RESOLUTION MSC. 302(87).
• Can output speed for any set location, allowing monitoring of bow and stern berthing speeds without the use of optional equipment.
• Perfect for use as a heading sensor for RADAR/ARPA, AIS, ECDIS and scanning SONARs.
• There are no mechanical parts such as gimbals or a rotating motor, thus the compass is free from routine maintenance.
• Geomagnetism does not affect the compass performance, making it usable on any vessel.
• No need for speed correction, unlike a gyrocompass.
• Short setting time
• Easily integrated into existing ship-board network via Ethernet.
• Remote Maintenance Service (RMS) ready, allowing hassle-free assistance when in port.
• Can be connected using existing antenna cabling (SC-50/60/110/120 only) by adding the optional conversion kit. Note that existing antennas units must be replaced. (Non-IMO type only)
• Uses multiple satellite types, eliminating the problem of not having enough satellites visible. (Non-IMO type only.)
Furuno Satellite Compass_SC70_130.pdf
Download [8 KB]
Alphatron Marine AutoPilot Instruction Manual (PilotSea, PilotRiv) - ALPHATRON [202x, PDF]
Furuno Operator’s manual Doppler Sonar Model DS-60 - Furuno [2010, PDF]
Furuno ECDIS Operator’s Manual FEA-2807/2107/2107-BB - [2005, PDF]
Satellite Compass A practical Guide to GNSS Transmitting Heading Devices for Marine Navigation - Spe...
Simrad GPS Compass User Manual (HS70, HS75, HS80A, MX575D, HS80A, MX575D) - Navico Holding AS [2019,...
Furuno ECDIS Operator’s Manual FEA-2107/BB/2108 - v.06.50 [2017, PDF] - Furuno
JRC GPS Compass Instruction Manual (JLR-21, JLR-31) - JRC [2021, PDF]
JRC Electromagnetic Log Users Manual Series EML-500 - JRC [2007, PDF]
AlphaPilot MFM Operation Manual - Alphatron marine [2019, PDF]
The time now is: Today 04:30
