Novice_User ®   27-Jan-2019 15:21
Furuno Echo Sounder FE-800
Year: 2014
Author: Furuno
Publisher: Furuno
Edition: A3
Pages count: 52
Description: The FE-800 is a color navigation echo sounder which operates with 50 or 200 kHz frequency. The
FE-800 is comprised of a control unit, transceiver, matching box and transducer. Echoes are
output on an 8.4-inch LCD screen.
The main features of the FE-800 are:
• Complies with the following regulations:
ISO9875:2000, IEC60945 Ed.4, IEC61162-1 Ed.4, IEC61162-1 450, IEC62288 Ed.2.
• Can display dual frequency (50 kHz/200 Khz) depth reading on one screen.
• Three display modes available:
• NAV mode: Standard display showing depth readings.
• OS DATA mode: Shows own ship location, time, COG/SOG alongside current depth
readings.
• HISTORY mode: Shows past readings in graph form alongside current depth readings.
• Can be connected to an external monitor (RD-20/RD-50) for remote display of readings.
• Compatible with Bridge Alert Management systems - IMO MSC.302(87)
• Can connect up to two transceivers, allowing dual on-screen display of echoes.
• Connecting the optional printer allows printing of echo data.
• Can save/replay up to 24 hours of depth reading history.
• Connecting a PC with the optional data recording software allows recording of echo data.
Download [9 KB]
Furuno Felcom 18 Inmarsat-C Operators Manual - Furuno [2012, PDF]
Furuno Dual GPS GP-90-DUAL - Furuno [2003, PDF]
Samyung ENC Chart Plotter N500/N560/NF560 Installation and Operation Manual - Samyung ENC [2009,…
JRC GPS Navigator Instruction Manual JLR-7500-7800 - JRC [2009, PDF]
The time now is: Today 13:22
