mmhkhang ®   05-Jul-2021 04:17
Alphatron Marine AutoPilot Instruction Manual (PilotSea, PilotRiv)
Year: 202x
Author: ALPHATRON
Publisher: ANPHATRON
Pages count: 352
Description: The Alphatron AlphaPilot MFM system is a type approved Heading Control System (i.e. Autopilot)
with self-adjusting ‘Auto Tune’ algorithm, designed to fit vessels of any size, including high speed
crafts. It is a modern and technologically advanced digital vessel control unit that is intended to
reduce the operator’s workload, increase the vessel motion efficiency and improve operational
safety.
The AlphaPilot MFM control unit is the main control module of the AlphaPilot MFM system. It is
used for control and monitoring of autopilot operation, setting vessel heading or rudder angle,
selection of autopilot operating modes.
• Thoroughly read this operation manual before operating the equipment.
• We recommend keeping this manual nearby the equipment to ensure ready access to it.
The ALPHAPILOT MF is one of the products from the Alpha Line MF. The ALPHAPILOT MF has
been specially developed for inland shipping. By default, the ALPHAPILOT MF is suitable to be
steered manual with the steering lever and also function as an autopilot. Optionally, one can
also connect an electronic compass (or GPS/satellite compass) and use that as a reference. In
result both gyro and compass will serve then as sensor input and combine functions between
turn indicator and compass. The pilot is able to feed signals to black / white or proportional
valves. Also special servo output is available to control Rudder propeller systems e.g.
Download [16 KB]
AlphaPilot MFM Operation Manual - Alphatron marine [2019, PDF]
JRC GPS Compass Instruction Manual (JLR-21, JLR-31) - JRC [2021, PDF]
Furuno Operator’s Manual Satellite Compass Model SC-70, SC-130 - Furuno [2020, PDF]
JRC Marine Radar Instruction Manual JMA-5300 Series - JRC [2013, PDF]
Samyung SDF-310 Standalone Digital Fishfinder User Manual - Samyung ENC [2014, PDF]
JRC Doppler Sonar Instruction Manual JLN-550 - JRC [2013, PDF]
Furuno Felcom 82 Inmarsat-B Operators Manual - Furuno [2005, PDF]
JRC Marine Radar Instruction Manual JMA-9172-SA - JRC [2011, PDF]
JRC Gyrocompass Users Manual CMZ 900D - JRC [2009, PDF]
Sperry Marine Analogue Compass Repeaters Types 5016-CA, 5016-CB, 5016-CC, 5016-CD Operation,…
The time now is: Today 15:05
