Gogo81 ®   09-Apr-2020 22:01
Boatbuilding and repairing with fiberglass
Year: 1972
Author: Melvin Willis
Genre: Handbook
Publisher: International Marine
Edition: First
ISBN: 0877420181
Pages count: 197
Description: A fiberglass hull is a thin (1/8" to 1/4") shell usually composed of two
distinct layers: outermost is a thin (1/64") layer of colored, hard, shiny
resin which gives a bright finish; inside of the first layer, and bonded to
it, is one or more layers of fiberglass cloth saturated with polyester resin.
The cloth is made of flexible but strong glass strands; the resin is rigid
(when cured) but not strong. Resin plus fiberglass cloth results in a rigid,
strong reinforcement for the thin, fragile, but hard and shiny, outer layer.
The overall composite shell is watertight, rot-proof, insect-proof, and
fairly easy to keep clean. Designed properly, fiberglass construction can
be as strong as conventional wood construction.
WHY FIBERGLASS?
What is all the excitement about fiberglass? Is it really as good as,
or better than, other boatbuilding materials? The tests conducted on
three Coast Guard patrol boats provide an answer: “A Report on Long
Term Durability of Fiberglass Boats,” appearing in Yachting (September,
1962), reveals that fiberglass is a superior material for marine use.
Download [8 KB]
Epoxy resins in boatbuilding - Practical tips [PDF]
Boatbuilding: Cold-moulded and Strip-Planked Wood - Nicolson I. [2016, EPUB]
Requirements for Bonded and Composite Repairs of Steel Structures and Piping - ABS [2022, PDF]
The Elements of Boat Strength: For Builders, Designers, and Owners - Dave Gerr [1999, PDF]
The Fiberglass Boat Handbook - Jack Willey [1987, PDF]
Illustrated Guide for Building a Spira International Stitch And Glue Boat - Spira J.J. [2010, PDF]
Fiberglass Boat Repairs Illustrated - Roger Marshall [2009, PDF]
West System Fiberglass Boat Repair & Maintenance - West System [2014, PDF]
Ultralight Boatbuilding - Hill T.G. [1987, PDF]
Adhesives in marine engineering - Jan R. Weitzenbock [2012, PDF]
The time now is: Today 01:23
