dumurcu ®   01-Aug-2022 21:52
West System Fiberglass Boat Repair & Maintenance
Year: 2014
Author: West System
Genre: Technical book
Pages count: 156
Description: The techniques described in this manual are based on the handling characteristics
and physical properties of WEST SYSTEM Epoxy products. Because physical properties
of resin systems and epoxy brands vary, using the techniques in this publication with
coatings or adhesives other than WEST SYSTEM is not recommended. This manual is
updated as products and techniques change.
The information presented herein is believed to be reliable as of publication date,
but we cannot guarantee its accuracy in light of possible new discoveries. Because
Gougeon Brothers, Inc. cannot control the use of its products in customer possession,
we do not make any warranty of merchantability or fitness for a particular use
or purpose. In no event, shall Gougeon Brothers, Inc. be liable for incidental or
consequential damages.
Table of contents
1 Introduction
1.1 Typical fiberglass boat construction . . . . . . . . . . . 1
1.2 WEST SYSTEM Epoxy for fiberglass repair . . . . . . . . . . 4
2 Repairing Minor Cracks and Holes
2.1 Minor crack and abrasion repair . . . . . . . . . . . . 6
3 Repairing Stringers and Floors
3.1 Reinforcing to improve panel stiffness . . . . . . . . . . 8
3.2 Repairing local core damage . . . . . . . . . . . . . 9
3.3 Stringer repair guidelines . . . . . . . . . . . . . . 10
3.4 Replacing active core sections . . . . . . . . . . . . 10
3.5 Replacing stringers . . . . . . . . . . . . . . . 11
3.6 Reinforcing to improve panel stiffness . . . . . . . . . . 14
4 Repairing Damaged Skins
4.1 Assessing and preparing the damaged area . . . . . . . . 19
4.2 Backing a repair patch . . . . . . . . . . . . . . . 20
4.3 Laminating a repair patch . . . . . . . . . . . . . . 23
5 Repairing Core Related Damage
5.1 Repairing skin delamination . . . . . . . . . . . . . 26
5.2 Replacing damaged cores . . . . . . . . . . . . . . 29
5.3 Repairing transom delamination . . . . . . . . . . . . 31
5.4 Repairing holed panels . . . . . . . . . . . . . . 37
6 Repairing and Upgrading Soles and Decks
6.1 Repairing delaminated soles and decks . . . . . . . . . . 40
6.2 Installing a teak deck . . . . . . . . . . . . . . . 42
7 Installing Hardware
7.1 Bonding fasteners . . . . . . . . . . . . . . . . 45
7.2 Bonding fasteners and hardware . . . . . . . . . . . 46
7.3 Casting epoxy bases for hardware . . . . . . . . . . . 50
7.4 Making fasteners removable . . . . . . . . . . . . . 51
7.5 Removing bonded hardware . . . . . . . . . . . . . 51
8 Repairing Keels and Rudders
8.1 Repairing internal ballast keels . . . . . . . . . . . . 53
8.2 Repairing external ballast keels . . . . . . . . . . . . 54
8.3 Repairing a keel hull joint . . . . . . . . . . . . . . 55
8.4 Repairing worn rudder bearings . . . . . . . . . . . . 56
9 The Problem of Gelcoat Blisters in Fiberglass Boats
9.1 Factors affecting blister formation . . . . . . . . . . . 58
9.2 WEST SYSTEM Epoxy for repair and coating . . . . . . . . . 61
9.3 Recommendations for the repair and prevention of gelcoat blisters . . 63
10 Hull Preparation
10.1 Evaluating blister damage . . . . . . . . . . . . . 64
10.2 Minor isolated blister damage . . . . . . . . . . . . 65
10.4 Exposing and removing interlaminate damage . . . . . . . . 67
10.5 Special preparations for new boats . . . . . . . . . . . 68
11 Drying the Laminate
11.1 How dry is dry? . . . . . . . . . . . . . . . . 69
11.2 Passive drying . . . . . . . . . . . . . . . . . 70
11.3 Active drying . . . . . . . . . . . . . . . . . 70
12 Repairing Blister Damage
12.1 Minor isolated blister damage . . . . . . . . . . . . 72
12.2 Extensive blister damage . . . . . . . . . . . . . . 73
12.3 Interlaminate damage . . . . . . . . . . . . . . . 74
13 Barrier Coating
13.1 Preparation . . . . . . . . . . . . . . . . . . 78
13.2 Applying the barrier coat . . . . . . . . . . . . . . 79
13.3 Bottom paint . . . . . . . . . . . . . . . . . 80
13.4 Recommendations for blister prevention . . . . . . . . . 81
14 Final Fairing
14.1 Establishing a fair level . . . . . . . . . . . . . . 83
14.2 Removing high areas . . . . . . . . . . . . . . . 84
14.3 Filling low areas . . . . . . . . . . . . . . . . 85
14.4 Local fairing . . . . . . . . . . . . . . . . . 92
15 Finishing
15.1 Epoxy barrier coating . . . . . . . . . . . . . . . 94
15.2 Final surface preparation . . . . . . . . . . . . . . 96
15.3 Finish coatings . . . . . . . . . . . . . . . . . 96
16 Using WEST SYSTEM Epoxy
16.1 Epoxy safety . . . . . . . . . . . . . . . . . 104
16.2 Epoxy products . . . . . . . . . . . . . . . . 105
16.3 Handling epoxy . . . . . . . . . . . . . . . . 107
16.4 Basic techniques . . . . . . . . . . . . . . . . 112
Appendix A
Tools . . . . . . . . . . . . . . . . . . . . . 123
Lofting foil shapes for rudders and keels . . . . . . . . . . . 126
Cold temperature bonding . . . . . . . . . . . . . . . 127
Additional reading . . . . . . . . . . . . . . . . . . 129
Appendix B
Estimating guides for WEST SYSTEM products . . . . . . . . . . 130
Epoxy handling . . . . . . . . . . . . . . . . . . 132
Appendix C
Applying fiberglass overhead . . . . . . . . . . . . . . 133
Appendix D
Repairing machined holes in fiberglass laminate . . . . . . . . . 135
Appendix E
Problem solving guide . . . . . . . . . . . . . . . . 140
Problem solving notes . . . . . . . . . . . . . . . . 142
Index . . . . . . . . . . . . . . . . . . . . . 143
Fiberglass-Manual-2015.pdf
Download [5 KB]
The Fiberglass Boat Repair Manual - Allan Vaitses [1988, PDF]
Wooden Boat Restoration & Repair - WEST SYSTEM® epoxy [2003, PDF]
Bulk Carriers: Guidelines for Surveys Assessment and Repair of Hull Structure - CCS [2014, PDF]
The Gougeon Brothers on Boat Construction - Meade Gougeon [2005, PDF]
User Manual & Product Guide - WEST SYSTEM Epoxy [2020, PDF]
Shipbuilding (Gemi İmalatı) - Ahmet Tokgöz, Atilla Yurdagül [2020, PDF]
Fiberglass Boat Repairs Illustrated - Roger Marshall [2009, PDF]
Sailing Yacht Design - A. Shenoi et alli [2009, PDF]
Hearst Marine Books Complete Guide to Boat Maintenance and Repair - David G. Brown [1993, PDF]
The time now is: Today 18:38
