Gogo81 ®   09-Apr-2020 20:57
The Fiberglass Boat Handbook
Year: 1987
Author: Jack Willey
Genre: Handbook
Publisher: Tab Books
Edition: First
ISBN: 0-8306-0499-5
Pages count: 356
Description: While there are certainly both advantages and disadvantages
in using fiberglass, the advantages largely outweigh the disadvantages.
Fiberglass does not suffer from dry rot or worms, a common
problem with wood; from rust, a common problem with steel;
or from electrolysis, common problems with both steel and aluminum
boats. Fiberglass boats require relatively little maintenance,
certainly less than required by other materials. They are, however,
still far from maintenance-free.
This book is primarily about the fiberglass part of boats. Most
so-called "fiberglass" boats use a variety of other materials in their
construction, such as wood for bulkheads and trim, rigid foam for
core and flotation purposes, metal for engines and fittings and
fasteners, and fabrics for upholstery. While the whole boat will be
treated to some degree, the focus will be on the fiberglass portion.
The vast popularity and acceptance of fiberglass boats have
created a real need for a how-to handbook on the subject. There
are three main aspects to this book.
The first deals with understanding,
selecting, purchasing, and owning fiberglass boats. The second
part covers caring for, maintaining, equipping, altering, and repairing
fiberglass boats. The third aspect is an introduction to
finishing out bare hulls and fiberglass kit boats, which are available
from a number of manufacturers, and one-off fiberglass boatbuilding
methods.
The fiberglass boat handbook
Metal boats - Ken Scott [1994, PDF]
The complete guide to metal boats: building, maintenance, and repair - Roberts-Goodson Bruce [2001,…
The Elements of Boat Strength: For Builders, Designers, and Owners - Dave Gerr [1999, PDF]
Boatowner’s Guide to Modern Maintenance - John Duffett [1985, PDF]
Maintenance and Repairs: Keeping Your Boat Looking and Operating Like New - Lawrence K. [1989, PDF]
Metal Corrosion in Boats: The Prevention of Metal Corrosion in Hulls, Engines, Rigging and Fittings…
Boating magazines: the boat doctor - Allen Berrien [1998, PDF & EPUB]
Boatbuilding with Aluminum - Stephen F. Pollard [1993, PDF]
Boatbuilding Manual - Steward R.M. [1980, PDF]
The Boat Repair Bible (Repair Guide) - Rupert Holmes [2012, PDF]
The time now is: Today 18:57
