CaptainWhite ®   02-Nov-2017 18:10
The Boat Repair Bible (Repair Guide)
Year: 2012
Author: Rupert Holmes
Publisher: Adlard Coles Nautical
Edition: 1st edition
ISBN: 978-1408133217
Pages count: 594
Book price: $35.99
Description: Even the most well designed boats will suffer from wear and tear due to normal use on the water. And accidents can result in damage which needs to be repaired on the spot. Highly illustrated, with step by step instructions, this book equips the reader with the vital skills needed to make those crucial repairs.
The Boat Repair Bible covers the most common types of damage likely to occur to boats of all types. Hull and deck repairs cover fibreglass, wood, steel and ferro-cement, showing how to deal with everything from leaks to serious impact damage. Standing and running rigging are covered as are deck fittings, hatches and steering gear.
The section on general mechanics shows how to fix problems with a split fuel/water tank and leaking hydraulics, whilst electrical repairs cover tracing loose connections, replacing damaged wiring and fixing navigation instruments. The myriad of issues that can arise with the engine are covered in great detail, from how to deal with water in the fuel system to replacing the propeller and its shaft. And there is even a section on domestic items, such as repairing upholstery, and fixing problematic heads.
The Boat Repair Bible is as comprehensive as it is invaluable and perfect for owners of powerboats, yachts, sailboats, dinghies and outboards. It is a book no boat owner can afford to be without.
Boat Bible
Download [10 KB]
borric   21-Nov-2017 10:16
As someone interested in eventually owning a classic beautiful cruising yacht that must first be obtained at the cheapest possible price....most of the boats I see in my price range are somewhere between suspicious and alarming.
Having a book like this helps to bring the problems into individual focus, making the whole process seem much more like an educated decision. Absolutely invaluable, I will get so much use out of this ^^ (I hope)
The Dinghy Bible - Rupert Holmes, Jeremy Evans [2014, EPUB]
The Knot Bible - A Practical Guide to the 200 Most Useful Nautical Knots, Compton N. [2013, PDF]
The Complete Day Skipper: Skippering with Confidence Right From the Start, 6th edition - Tom Cunliff...
Replacing your Boat’s Engine - Mike Westin [2012, EPUB]
Narrow Boat Engine Maintenance and Repair - Horton S. [2017, EPUB]
Your Boat Belowdecks - Thomas Reale and Michael Johnson. [1990, PDF]
Maintenance and Repair for Outboard Motors - Jean Luc Pallas [2013, EPUB]
Vital First Aid - Vital First Aid Training Services [2019, PDF]
IICL: Supplement on Inspection & Repair - Gray Areas, 2nd Edition - IICL [2003, PDF]
Boat Building Techniques lllustrated - Richard Birmingham [2005, PDF]
The time now is: Today 05:34
