ersten ®   08-May-2021 20:55
Metal boats
Year: 1994
Author: Ken Scott
Genre: Technical book
Publisher: Sheridan House Inc
ISBN: 9780924486685
Pages count: 208
Description: A concise guide to building or buying aluminum and steel craft.
Scott dispassionately explains how to compensate for the metal's liabilities while taking advantage of its notable assets. Scott takes the reader logically from the basics about material qualities and how to prevent problems like electrolysis, through the entire building process. He deciphers some drawings and goes step-by-step through building the hull, installing machinery, insulation interior, then provides sources for designs and designers.
It is a very useful little book to anyone involved in building or buying a metal boat or even for anyone who currently owns a metal boat and may be thinking of making improvements to it. The book provides a simple and very useful guide to the subject. It is well illustrated and covers almost every imaginable aspect of metal boats.
Steel or aluminum will give you many advantages over other boatbuilding materials, writes Ken Scott, who built his own steel boat 10 years ago and lived happily ever after. Why? No delamination of fiberglass; no gelcoat bubbles; stanchions and other fittings welded right to the hull without need for drilled holes and bedding compound; cheaper hull construction compared with custom fiberglass; more forgiving if you go aground or hit a ledge.
If you ever wanted to know more about metal-boat construction, this is the book. Not a technical manual, but an overview, it is a guide to the plusses and minuses of metal boats, design considerations, steel and aluminum types, dealing with corrosion, welding methods, things to consider when having a metal hull custom built, joinerwork, installing engines and associated gear, and more. The explanations are simple and clear, with enough technical information to help you decide if this is a construction material you would be comfortable with, but not so much that the forest is missed for all the trees. In other words, this book is for those who want to know why they should consider metal boats, or why not, and how they should go about obtaining one home built, custom built, or a combination of the two if they decide that is what they want. Best of all are the excellent photographs of metal yachts under construction and a special section containing yacht designs, sail and power.
Ken Scott - Metal boats
Download [21 KB]
The complete guide to metal boats: building, maintenance, and repair - Roberts-Goodson Bruce [2001,…
The Fiberglass Boat Handbook - Jack Willey [1987, PDF]
Boatbuilding with Aluminum - Stephen F. Pollard [1993, PDF]
Illustrated Custom Boatbuilding - Bruce Roberts-Goodson [2008, PDF]
Boatbuilding Manual - Steward R.M. [1980, PDF]
The Proper Yacht - Arthur Beiser [1966, PDF]
Yacht Joinery and Fitting. Practical Guidance on the Planning and Building of Cabin Accommodation…
Principles of yacht design - L. Larsson, R.E. Eliasson [2000, PDF]
Ultrasimple Boatbuilding - 17 Plywood Boats Anyone Can Build - Atkin C. [2008, PDF]
The Offshore Yacht - Tim Thornton [1984, PDF]
The time now is: Today 14:13
