paolina_3 ®   19-Jul-2020 22:35
Wire Ropes Tension, Endurance, Reliability, 2nd Edition
Year: 2015
Author: Klaus Feyrer
Publisher: Springer
Edition: 2nd
ISBN: 978-3-642-54996-0
Pages count: 343
Description: This manual is aimed to all users of wire ropes; engineers, operators and supervisors of machines and installations with wire ropes. It has been the main concern of this book to present the methods used to calculate the most important rope quantities (rope geometry, wire stresses in the rope under tension, bending and twist, rope elasticity module, torque, rope efficiency, the bearable number of load cycles or bending cycles and the discard number of wire breaks, etc.), as well as to explain how they are applied, with a large number of example calculations. This second edition presents new research works in the field of wire rope twist and the size effect. Many new calculations and examples have also been added to facilitate the dimensioning and calculation of mechanical characteristics of wire ropes.
Wire Ropes Tension, Endurance, Reliability, 2nd Edition.pdf
Download [5 KB]
Theory of Wire Rope, 2nd Edition - George A. Costello [1997, PDF]
Knots and lashings - Totem pole scouters foundation [1993, PDF]
Knots, bends, splices - with tables of strengths of ropes, etc., and wire rigging - Capitan Jutsum [...
Exploration of Gas Hydrates - Geophysical Techniques - Naresh Kumar Thakur & Sanjeev Rajput [2011, P...
Samson Technical Bulletin - Samson rope Inc [2018, PDF]
Dynamics of Crank-Piston Mechanisms - Nodar Davitashvili • Valeh Bakhshaliev [2016, PDF]
Variable Geometry Turbine Technology for Marine Gas Turbines - Gao J. et al. [2022, PDF]
Vryhof Manual The Guide to Anchoring - Vryhof Anchors B.V. [2015, PDF]
Fatigue assessment of stern ramps - ARON JALKEVIK AND KARL TORESSON [2013, PDF]
The time now is: Today 02:57
