virtual ®   12-Oct-2019 23:50
A Heat Transfer Textbook, 5th Edition
Year: 2019
Author: John H. Lienhard IV and John H. Lienhard V
Publisher: Phlogiston Press
Pages count: 784
Description: People have always understood that something flows from hot objects to
cold ones. We call that flow heat. Scientists of the late eighteenth century
finally decided that all bodies must contain an invisible fluid which they
called caloric. Caloric was assigned a variety of properties, some of which
proved to be inconsistent with nature—for example, caloric had weight
and could not be created or eliminated. But the most important property
was that caloric flowed from hot bodies into cold ones. Caloric provided
a very useful way to think about heat.
The book is meant for juniors, seniors, and first-year graduate students.
We also want it to be of use to those who choose to learn the subject on
their own, and to practicing engineers who use it as a reference. Whether
one studies alone or with a class, learning means posing, then answering,
one’s own questions.
AHTTv500.pdf
Download [16 KB]
Fundamentals and Technology of Combustion - Fawzy El-Mahallawy, Saad El-Din Habik [2002, PDF]
Engineering Thermodynamics - R.K. Rajput [2007, PDF]
Mechanical measurements - S. P. Venkateshan [2015, PDF]
The Invisible Hook: The Hidden Economics of Pirates - Peter T. Leeson [2011, PDF]
Autonomous Underwater Vehicle Propeller Simulation using Computational Fluid Dynamic - Husaini M. at...
An Album of Fluid Motion - Van Dyke [1982, PDF]
Dynamics of Water Surface Flows and Waves - Yasunori Watanabe [2022, PDF]
The British Navy in the Baltic - John D. Grainger [2014, PDF]
Marine Interfaces Ecohydrodynamics - Nihoul J.C.J. (Eds.) [1986, PDF]
Fundamentals of Heat Exchanger Design - Ramesh K. Shah, Dušan P. Sekulic [2003, PDF]
The time now is: Today 22:54
