marlamamba ®   20-Aug-2019 21:22
Engineering Thermodynamics
Year: 2007
Author: R.K. Rajput
Publisher: Laxmi Publications Ltd.
Edition: 3rd.
ISBN: 978-0-7637-8272-6
Pages count: 966
Description: Intended as an introductory textbook for 'applied' or engineering thermodynamics, or for use as an up-to-date reference for practicing engineers, this book provides extensive in-text, solved examples to cover the basic properties of thermodynamics. Pure substances, the first and second laws gases, psychometrics, the vapour, gas, and refrigeration cycles, heat transfer, compressible flow, chemical reactions, fuels, and more are presented in detail and enhanced with practical applications. This version presents the material using SI Units and has ample material on SI conversion, steam tables, and a mollier diagram.
Engineering Thermodynamics.pdf
Download [8 KB]
Thermodynamics Demystified - Merle C. Potter [2009, PDF]
Schaum’s Outline of Theory and Problems of Thermodynamics For Engineers - Merle C. Potter, Craig W.…
REEDS Vol 3: Applied Thermodynamics for Marine Engineers - Paul Anthony Russell, William Embleton,…
Engineering fundamentals of the internal combustion engine - Willard W. Pulkrabek [2003, PDF]
Modern Marine Engineer’s Manual Volume 2 - Everett C. Hunt [2002, EPUB/PDF/AZW]
Modern Marine Engineer’s Manual Volume 1 - Everett C. Hunt [2010, PDF]
Introduction to Refrigeration and Air Conditioning Systems - Allan T. Kirkpatrick [2023, PDF]
Handbook of Fire and Explosion Protection Engineering Principles for Oil, Gas, Chemical and Related…
Hydraulic Structures - C. S. James [2020, PDF]
REEDS Vol 9: Steam Engineering Knowledge for Marine Engineers - Thomas D. Morton [2003, PDF]
The time now is: Today 16:45
