John11 ®   05-Oct-2014 22:08
Design Rules for Actuators in Active Mechanical Systems
Year: 2009
Author: Gomis-Bellmunt O., Campanile F.
Publisher: Springer
ISBN: 1848826133
Pages count: 205
Description:In active mechanical systems (mechanisms or structures) the possibility of a coupling between active and passive elements at an early stage of the design process is becoming more and more significant. In order to integrate actuators in preliminary design procedures, or in a multidisciplinary optimization approach, reliable models of the actuator performance (actuator force and stroke, loading curves, strength limit, volume and mass specific work and power, frequency range, efficiency) as a function of the design parameters and variables (actuator principle, size of the actuator element) are necessary.
Design Rules for Actuators in Active Mechanical Systems deals with the formulation of model-based design rules to be used in the conception of optimized mechatronic and adaptronic systems. The book addresses the comparison of different actuator classes for given applications and offers answers to the following questions:
What is the relationship between actuator geometry and primary output quantities?
How scalable are actuators based on the same principle?
How are energetic output quantities (work and power) related to mechanical load and geometry?
How should actuators be designed and sized to obtain the best performance for the chosen actuator kind, and for a given application?
Design Rules for Actuators in Active Mechanical Systems will be of use to industry professionals, such as actuator and machine designers, as well as to researchers and students of mechanical engineering, mechatronics, and electrical engineering.
gomisbellmunt_o_campanile_f_design_rules_for_actuators_in_ac.pdf
Download [15 KB]
Research on Ship Design and Optimization Based on Simulation-Based Design (SBD) Technique - Bao-Ji Z...
Udemy Course - Compressors introduction in Oil & Gas Industry [2022, MP4]
Kite Dynamics for Ship Propulsion - G. M. Dadd [2012, PDF]
Handbook of Valves and Actuators - Brian Nesbitt [2007, PDF]
MAN B&W S70ME-C8.5-TII Project Guide Electronically Controlled Two-stroke Engines - MAN [2018, PDF]
Udemy Course - Pumps in Oil and Gas industry [2022, MP4]
Ship Power Systems 2005 - Wartsila [2005, PDF]
Ship Power Systems - Wartsila [2006, PDF]
Ship Power Systems - Wartsila [2007, PDF]
Ship Motion Control: Course Keeping and Roll Stabilisation using Rudder and Fins - Tristan Perez [20...
The time now is: Today 15:02
