SerTan ®   14-Dec-2016 04:25
Handbook of Valves and Actuators
Year: 2007
Author: Brian Nesbitt
Genre: Handbook
Publisher: ELSEVIER
ISBN: 1-85617-494-8
Pages count: 540
Description: Industries that use pumps, seals and pipes will also use valves and actuators in their systems. This key reference provides anyone who designs, uses, specifies or maintains valves and valve systems with all of the critical design, specification, performance and operational information they need for the job in hand. Brian Nesbitt is a well-known consultant with a considerable publishing record. A lifetime of experience backs up the huge amount of practical detail in this volume.
* Valves and actuators are widely used across industry and this dedicated reference provides all the information plant designers, specifiers or those involved with maintenance require
* Practical approach backed up with technical detail and engineering know-how makes this the ideal single volume reference
* Compares and contracts valve and actuator types to ensure the right equipment is chosen for the right application and properly maintained
Handbook of Valves and Actuators (Brian Nesbitt 2007).pdf
Download [10 KB]
Valves, Piping and Pipelines Handbook - T.Dickenson [1999, PDF]
Surface Production Operations Volume IV - Pumps and Compressors - Maurice Stewart [2019, PDF]
Handbook of pumps and pumping - Brian Nesbitt [2006, PDF]
Cranes Design, Practice and Maintenance - Ing. J. Verschoof [2002, PDF]
Design Rules for Actuators in Active Mechanical Systems - Gomis-Bellmunt O., Campanile F. [2009,…
Valve Handbook - P.Skousen [2011, PDF]
Fundamentals of Valves and Piping for Ships - IMMAJ [2011, PDF]
Control Valve Handbook - Emerson Process Management [2005, PDF]
Pressure Relief Valve Engineering Handbook - Anderson Greenwood [2012, PDF]
The time now is: Today 16:52
