Geronim0 ®   04-Apr-2019 01:30
IEC 62040-1-2017 Uninterruptible power systems (UPS ) – Part 1 : Safety requirements
Year: 2017
Author: IEC
Genre: Normative document
Pages count: 150
Description: This part of IEC 62040 applies to movable, stationary, fixed or built-in UPS for use in low voltage distribution systems and that are intended to be installed in an area accessible by an ordinary person or in a restricted access area as applicable, that deliver fixed frequency AC output voltage with port voltages not exceeding 1000 VAC or 1500 VDC and that include an energy storage device. It applies to pluggable and to permanently connected UPS, whether consisting of a system of interconnected units or of independent units, subject to installing, operating and maintaining the UPS in the manner prescribed by the manufacturer.
IEC 62040-1-2017.pdf
Code for Lifting Appliances in a Marine Environment - Lloyd’s Register [2022, PDF]
IEC 60092 - Electrical Installations in Ships - IEC [2016, PDF]
Basic Electrical Engineering | Synchronous Generator - Tinesh Mahajan [2021, PDF]
IEC 62040-1:2017 & IEC 62040-3:2011 - Uninterruptible power systems (UPS)
Fact Worth Knowing About Frequency Converters - Danfoss [1998, PDF]
Guidance on Line Management Plans (LMP) - INTERTANKO [2019, PDF] - INTERTANKO [2019, PDF]
Power Transformers - Principles and Application - J.Winders [2002, PDF]
High Voltage Safety - Antwerp Maritime Academy [20XX, PDF]
Samyung SNX-300 NAVTEX Receiver User Manual - Samyung ENC [2006, PDF]
The Selection and Testing of Valves for LPG Applications - SIGTTO [2012, PDF]
The time now is: Today 19:00
