pakasi ®   16-Mar-2022 20:23
Basic Electrical Engineering | Synchronous Generator
Year: 2021
Author: Tinesh Mahajan
ISBN: B09JM6TCWX
Pages count: 53
Description: The electric supply used for industrial and domestic application is of alternating type. This is so because a highly efficient device called transformer is available. It is capable of transferring electrical energy from one circuit to another at different voltage level. The transformer is used for economically transmitting and distributing electrical power over long distance. This has
permitted us to locate the generation of electric power remotely from the point of demand.
Generally, electric power is generated at about 11kV, then stepped up to higher voltages of 132kV, 220kV and 400kV for transmission lines. At distribution point, it is again stepped down to 400V or 220V for use in industry, offices and homes.
Many applications require the frequency of ac supply to be constant. Constant frequency of generated power can be obtained only if the generator runs at constant speed, called its synchronous speed. Hence, the name synchronous generator. Large size generators are also
called alternators.
N/A
BASIC ELECTRICAL ENGINEERING _ SYNCHRONOUS GENERATOR.pdf
Power Transformers - Principles and Application - J.Winders [2002, PDF]
Fundamentals of Electric Machines: A Primer with MATLAB® - Warsame Hassan and Others [2019, PDF]
Electrical Engineering – Learn About Electronics v.1.0.0 - Up Studio Apps [2017] [Android]
Mobile Solar Power Made Easy! - William Errol Prowse IV [2018, PDF]
Electrical and Electronics Engineering eBooks [PDF]
Principles of Electric Circuits - Conventional Current Version - Thomas L. Floyd [2007, PDF]
Electrical systems in pod propulsion - Lena Bergh Ulrika Helldén [2007, PDF]
The Electric Power Engineering Handbook - L. Grigsby [2001, PDF]
Electrical Overview on Main & Auxiliary Generating Sets [2021, MP4]
Principles of Electric Machines and Power Electronics, 3rd Edition - P.C. SEN [2014, PDF]
The time now is: Today 11:00
