Novice_User ®   14-Jan-2019 20:45
Kelvin Hughes - X-VDR Voyage Data Recorder
Year: 2015
Author: Kelvin Hughes
Publisher: Kelvin Hughes
Edition: 1.07
Pages count: 127
Description: The “X-Series” VDR and interfaces have been developed using expertise in VDR design spanning more than
a decade, along with 20+ years’ experience in marine electronic re-transmission and interfacing. The result is
a system that is designed and built in the UK from the “ground up”. A system that not only meets the new VDR
regulations but offers more flexibility, functionality and features to the end user than ever before.
New Regulations: - in compliance with MSC.333(90), enforced by 1 July 2014, if installed on or after 1 July
2014, conform to performance standards not inferior to those specified in the annex to the present resolution:
and if installed before 1 July 2014, conform to performance standards not inferior to those specified in the
annex to resolution A.861(20), as amended by resolution MSC.214(81)
Cable Entry System:
The new “X-Series” VDR includes a compact and innovative design of cable gland. These cable glands are
ideal for applications where many cables are needed to run into a small space.
The VDR has specialised cable entry frames with compression inserts for installing pre-terminated cables e.g.
VGA, Ethernet cables directly into the VDR main unit. The selection of inserts can be customised to vessel
needs with cables entries from 2mm to 14mm
System Features:
• Compact and easy to use cable entry system
• Bridge Control Unit for efficient system monitoring
• 10 individual audio channels allowing up to 16x microphones and 2x VHF
• Compliant with MSC.333(90) and IEC61996-1 Ed 2.0
• 2 Year warranty as standard
• Global service and support network
Kelvin Hughes X-VDR.1
Download [4 KB]
Furuno Felcom 18 Inmarsat-C Operators Manual - Furuno [2012, PDF]
JRC Automatic Identification System JHS-183 - JRC [2012, PDF]
Furuno SSB Radiotelephone FS-1570/ FS- 2570 - Furuno [2002, PDF]
Furuno Operator’s Manual Satellite Compass Model SC-70, SC-130 - Furuno [2020, PDF]
Thrane & Thrane - BGAN-Explorer-325 Installation and User Manuals - Thrane & Thrane A/S [2015, PDF]
Furuno Felcom 19 Inmarsat-C Operators Manual - Furuno [2012, PDF]
Thrane & Thrane - Sailor FleetBroadband-150 Installation and User manuals - Thrane & Thrane A/S…
Thrane & Thrane - Sailor FleetBroadband-250/500 Installation and User manuals - Thrane & Thrane A/S…
SAILOR 500/250 FleetBroadband User manual Including 19” Rack Version - Thrane & Thrane A/S [2018,…
Thrane & Thrane - BGAN-Explorer-727 Installation and User Manuals - Thrane & Thrane A/S [2015, PDF]
The time now is: Today 15:15
