Arcan ®   07-Apr-2018 18:35
Thrane & Thrane - BGAN-Explorer-727 Installation and User Manuals
Year: 2015
Author: Thrane & Thrane A/S
Publisher: Thrane & Thrane A/S
Pages count: 179
Description: EXPLORER 727 is a land vehicular broadband system, that provides simultaneous high-speed
data and voice communication via satellite through the BGAN (Broadband Global Area
Network).
Applications include:
• Internet browsing
• E-mail
• Phone and fax services
• Large file transfers
• Video conferencing and Streaming
• VPN (Virtual Private Network) access to corporate servers
This chapter has the following sections:
• Features and interfaces
• Main units
• The Inmarsat BGAN system
• Services and interfaces
Features
 Simultaneous voice and data communication over BGAN
 Switch between Standard (on-the-move) and X-Stream (on-the-pause) mode.
 Full duplex, single or multi-user, up to: 492 kbps
 Support for streaming IP at:
In Standard (on-the-move) mode: 32, 64, 128 and 256 kbps
In X-Stream (on-the-pause) mode: 32, 64, 128, 176, 256 kbps and BGAN X-Stream™ (from a
minimum of 384 kbps up to approximately 450 kbps)
 ISDN (Integrated Services Digital Network) service: 64 kbps
 Voice: Standard Voice (4 kbps) or 3.1 kHz Audio
 4 LAN (Local Area Network) ports with PoE (Power over Ethernet) for computers, e-hubs, IP
handsets etc.
 2 Standard Phone/Fax ports for standard phones or fax machines
 1 Euro ISDN port for ISDN phones, G4 fax or ISDN modem
 1 multi-purpose I/O connector with 5 configurable inputs/outputs
 1 SIM slot for your BGAN SIM card
 Support for GPS, GLONASS and BeiDou-1 positioning systems
 Built-in DHCP/NAT router
 Built-in web interface allowing you to manage your phone book, messages and calls, and
customize the terminal to your specific needs
 Input power: 10.5 - 32 V DC (14 A - 5.5 A)
 CE certified
 Supports Inmarsat’s extended L-band services with Alphasat (Inmarsat I-4A F4)
Download [7 KB]
Thrane & Thrane - BGAN-Explorer-325 Installation and User Manuals - Thrane & Thrane A/S [2015, PDF]
Thrane & Thrane - Sailor FleetOne Installation and User manuals - Thrane & Thrane A/S [2015, PDF]
Thrane & Thrane - Sailor FleetBroadband-250/500 Installation and User manuals - Thrane & Thrane A/S ...
Thrane & Thrane - BGAN-Explorer-510 User Manual - Thrane & Thrane A/S [2015, PDF]
Thrane & Thrane - Sailor FleetBroadband-150 Installation and User manuals - Thrane & Thrane A/S [201...
Thrane & Thrane - BGAN-Explorer-710 User Manual - Thrane & Thrane A/S [2015, PDF]
SAILOR 500/250 FleetBroadband User manual Including 19” Rack Version - Thrane & Thrane A/S [2018, PD...
Furuno Felcom 250/500 Inmarsat Fleet BroadBand Operators Manual - Furuno [2012, PDF]
Furuno Felcom 70 Inmarsat Fleet F77 Operators Manual - Furuno [2009, PDF]
The time now is: Today 02:59
