chayan_09 ®   20-Nov-2018 10:35
The Welding of Aluminium and Its Alloys
Year: 2002
Author: Gene Mathers
Genre: Textbook
Publisher: Woodhead Publishing Limited
Pages count: 243
Description:
The book provides a basic understanding of the metallurgical principles involved in how alloys achieve their strength and how welding can affect these properties. Author have included sections on parent metal storage and preparation prior to welding and have also described the more frequently encountered processes. There are recommendations on welding parameters that may be used as a starting point for the development of a viable welding procedure. Also included are what author hopes will be useful hints and tips to avoid some of the pitfalls of welding these sometimes problematic materials.
This book can be a very good guide for a manual for aluminium welding procedure in different cases.
Preface ix
1 Introduction to the welding of aluminium 1
1.1 Introduction 1
1.2 Characteristics of aluminium 4
1.3 Product forms 6
1.4 Welding: a few definitions 6
2 Welding metallurgy 10
2.1 Introduction 10
2.2 Strengthening mechanisms 10
2.3 Aluminium weldability problems 18
2.4 Strength loss due to welding 31
3 Material standards, designations and alloys 35
3.1 Designation criteria 35
3.2 Alloying elements 35
3.3 CEN designation system 36
3.4 Specific alloy metallurgy 40
3.5 Filler metal selection 46
4 Preparation for welding 51
4.1 Introduction 51
4.2 Storage and handling 51
4.3 Plasma-arc cutting 52
4.4 Laser beam cutting 58
4.5 Water jet cutting 63
4.6 Mechanical cutting 64
4.7 Cleaning and degreasing 66
5 Welding design 69
5.1 Introduction 69
5.2 Access for welding 70
5.3 Welding speed 71
5.4 Welding position 72
5.5 Edge preparation and joint design 72
5.6 Distortion 84
5.7 Rectification of distortion 88
5.8 Fatigue strength of welded joints 89
6 TIG welding 97
6.1 Introduction 97
6.2 Process principles 97
6.3 Mechanised/automatic welding 114
6.4 TIG spot and plug welding 115
7 MIG welding 116
7.1 Introduction 116
7.2 Process principles 116
7.3 Welding consumables 130
7.4 Welding procedures and techniques 135
7.5 Mechanised and robotic welding 141
7.6 Mechanised electro-gas welding 143
7.7 MIG spot welding 144
8 Other welding processes 147
8.1 Introduction 147
8.2 Plasma-arc welding 147
8.3 Laser welding 150
8.4 Electron beam welding 155
8.5 Friction welding 160
9 Resistance welding processes 166
9.1 Introduction 166
9.2 Power sources 167
9.3 Surface condition and preparation 169
9.4 Spot welding 171
9.5 Seam welding 175
9.6 Flash butt welding 176
10 Welding procedure and welder approval 181
10.1 Introduction 181
10.2 Welding procedures 181
10.3 Welder approval 191
11 Weld defects and quality control 199
11.1 Introduction 199
11.2 Defects in arc welding 199
11.3 Non-destructive testing methods 205
Appendix A British and ISO standards related to
welding and aluminium 216
Appendix B Physical, mechanical and chemical
properties at 20°C 226
Appendix C Principal alloy designations: cast products 227
Appendix D Alloy designations: wrought products 228
Bibliography 230
Index 235
Welding of Alluminium and Its Alloys.pdf
Download [5 KB]
SerTan   20-Nov-2018 12:24
Pls shift info from Additional info to Description, as it more or less gives some kind of book description. It would be preferable to make it more short and more laconic view as well.
Info given presently at Description is looks like disclimer and not interisting for anybody exсept the book producer.
SerTan   20-Nov-2018 16:22
Your corrected Description is too small now. I did not mean such small review when recommended you to be laconic)))
I took an info from book Preface and placed it above instead of you. Next time pls make it youself. Find some sentences at annotation or at preface which will reflect book content.
Welding Handbook Volume 1, 2, 3 - American Welding Society [20XX, PDF]
Handbook of Laser Welding Technologies - Katayama S. (ed.). [2013, PDF]
Shipbuilding Technology - Welding of Ship Structures - V. N. Morozov [2011, PDF]
Ship Construction (Chief Mate Course) - Captain S.A Hosseini [20XX, PDF]
Applied Welding Engineering. Processes, Codes, and Standards - Ramesh Singh [2016, PDF]
Welding Metallurgy - Volume1 - George E. Linnert [1994, PDF]
Fundamentals Of Laser Welding [2020, MP4]
Ship Construction and Welding - Mandal, Nisith Ranjan [2017, PDF]
Welding Basics - 3G E-learning LLC [2024, PDF]
Welding: Principles and Applications - Larry Jeffus [2017, PDF]
The time now is: Today 15:09
