borex1 ®   31-Oct-2018 22:34
Build Your Own Sailboat
Year: 2017
Author: Roberts-Goodson Bruce
Genre: Reference book
Pages count: 1095
Description: Planning and how much will it cost. Your budget. Earn as you cruise. Setting up a workshop. Best boat size for cruising. Crew requirements: new or second-hand or build? The KISS factor.
Fully detailed construction methods for building in Fiberglass, Steel, Wood Epoxy with all methods fully explained ... Thousands of drawings and thousands of step by step photographs this is a complete boatbuilding book !
Hull types, including keels and other appendages. Selecting a hull type. Formulas and technical considerations . Displacement length ratios and meanings. Seaworthiness, hull balance, self steering capabilities with and without mechanical devices. Raised decks, poop sterns. All types of rigs fully explained. Underwater considerations; draft limitations, centre-boards, drop keels, twin keels. Rudder types; transom hung rudder.
Over 200 designs you can build in Steel, Fibeglass or Wood Epoxy. Step by step construction photos for all building methods. Hundreds of photos of completed boats including interiors etc.
CHAPTER 1.
History of Cruising Sailboats.
This chapter covers the history of the 'cruising' sailboat and tells of some of the characters that helped make it possible for us to enjoy cruising as we know it today.
CHAPTER 2.
Budgets & Planning
Here you will read about Initial planning and calculations of how much will it all cost. How to save money and keep within your budget. Budgets for acquiring your boat and for maintaining the cruising lifestyle. Earn as you cruise. Chartering your boat. Setting up a workshop. Boat size for cruising and crew requirements. Where to look: new or second-hand or build. All this and much much more !
CHAPTER 3
Choosing the Hull
Hull types, including keels and other appendages. Selecting a hull type. Formulas and technical considerations and what they mean. Displacement length ratios and meanings. Seaworthiness, hull ends, overhangs, hull balance, self steering capabilities with and without mechanical devices Slipping your hull and the ability to go aground. Raised decks, poop sterns and anchor wells. Self steering capabilities see also rig and self steering. Underwater considerations; draft limitations, types of ballast, centre-boards, drop keels, twin keels. Rudder types; transom hung rudder. Hull construction materials; selecting the hull material and the choice between glass fibre, steel, aluminium or wood, advantages and disadvantages of each. Motor Sailer hulls.
CHAPTER 4.
Decks and Superstructures
General configuration and layout above the deck-line. Decks and Superstructure arrangements; centre verses aft cockpit, raised decks, raised foredeck, raised poop or raised mid-ship layouts. Pilot houses. Window and port sizes. Hatches; types and sizes. Deck covering. Life lines, Pulpits and Push-pits.
CHAPTER 5.
Rigs and Sail boat plans
Choosing a sail plan for cruising; cutter, ketch, yawl or schooner. Modern or traditional. Un-stayed rigs, contemporary Bermudian or gaff. Types of standing and running rigging. Winches, reefing systems, bowsprits. Equipment for self steering. Other self steering devices. Extra sails and their uses; storm sails and spinnakers.
CHAPTER 6.
Choosing a Building Site
If you decide to custom build from scratch or a hull and deck package, you will need a suitable building site; this applies equally if you are building in fiberglass, steel or wood. Depending on where you live you may have many, or a limited number or choices. If you live in a warmer area, then a simple shelter will suffice. If your boat is to be built or completed in a cold climate, then you will to need to consider a heated structure.
CHAPTER 7.
Building in WOOD
This huge chapter covers all you will want to know about building a wooden sailboat. All methods are covered including traditional timber construction, wood epoxy, protecting and sheathing timber, there are examples of boats built from sawing own timber through to the laid deck etc.
CHAPTER 8.
Building in FIBERGLASS
This chapter covers the collecting of the correct tools and materials to build your own fiberglass boat. Purchasing and handling all the materials is explained in detail so that you will have the knowledge to build your own fiberglass sailboat.
CHAPTER 9.
Building in METAL
This chapter covers everything for those who are interested in building in Steel, Aluminum and Copper- Nickel. The benefits and disadvantages of the different metals are explained in detail. Discusses the right tools and equipment and welding techniques and how they apply to various metals. The differences between the various hull shapes is explained in detail plus selecting the correct engine(s) and equipment. Other subjects include electrolytic protection, building skegs. keels and pilot houses, in fact everything you need to know about metal boats is covered between the pages of this book. NEW information on building from a KIT ... many kit assembly photos etc etc.
CHAPTER 10.
Sailboat Engineering
The auxiliary engine. Horsepower requirements. Propeller types. Engine compartments. Fuel tanks and capacities. Water tanks. Cooling systems. Bilge pumps. Spare parts and Construction materials.
CHAPTER 11.
Sailboat Electrics
Glossary. Electrical installations. Domestic Batteries. Engine starting batteries. Battery chargers. Generating sets. Testing devices. Solar panels. Wind generators. Inverters
CHAPTER 12.
Sailboat Interiors
Accommodation; number of berths verses expected number of crew. Cabin soles. How many heads? Designing and equipping a galley. Various fuels for your stove (gas, diesel, alcohol, paraffin). Placement of sink and stowage of food and other stores. Showers, hot water and pressure water. Water tankage. Comfortable seating; measurements and suggestions. Chart table. Sail stowage. Refrigerators and ice boxes. Lighting. Ventilation. Heating.
THAT'S ENOUGH READING FOR NOW WE GUARANTEE YOU WILL ENJOY READING THIS HUGE e-BOOK
CHAPTER 13.
Sailboats 19ft to 30ft
CHAPTER 14.
Sailboats 31ft to 40ft
CHAPTER 15.
Sailboats 41ft to 50ft
CHAPTER 16.
Sailboats 51ft to 60ft
CHAPTER 17.
Sailboats 61ft to 80ft
CHAPTER 18.
What is a Spray
CHAPTER 19.
Spray 22, 27 ,28
CHAPTER 20.
Spray 33, 36 ,38, 40, 55
CHAPTER 21.
Cent. Spray 34, 36 ,38, 45, 50
CHAPTER 22.
Spray 340, 370, 400, 460, 52, 58
CHAPTER 23.
Safety
CHAPTER 24.
Ground Tackle
APPENDIX
Those many boaty' words from 'abaft' to 'work hardening' are among the many terms you may not know the meaning of; they are all explained in this in this index.
Build_Your_Own_Sailboat.pdf
Download [20 KB]
YYa   05-Nov-2018 18:24
Если товаришч не хочет раздавать, я могу новую раздачу на эту же тему сделать. Разыскал файло в тырнете...
Arcan   05-Nov-2018 19:06
YYa, Создавайте. Эту отправим в помойку, как только будет создана новая.
YYa   06-Nov-2018 01:04
Arcan, Ну, что-то вроде начало скачиваться. Если завтра будет то же самое, выложу.
The complete guide to metal boats: building, maintenance, and repair - Roberts-Goodson Bruce [2001,…
Illustrated Custom Boatbuilding - Bruce Roberts-Goodson [2008, PDF]
Upgrading Your Small Sailboat for Cruising - Paul and Marya Butler [1988, PDF]
The Proper Yacht - Arthur Beiser [1966, PDF]
Choosing for Cruising: How to Select and Equip the Perfect Cruising Yacht - Roberts-Goodson B.R.…
Metal boats - Ken Scott [1994, PDF]
The Elements of Boat Strength: For Builders, Designers, and Owners - Dave Gerr [1999, PDF]
Boatowner’s Mechanical and Electrical Manual - How to Maintain, Repair, and Improve Your Boat’s…
Boatbuilding with Aluminum - Stephen F. Pollard [1993, PDF]
Ted Brewer Explains Sailboat Design - Brewer T. [1985, PDF]
The time now is: Today 23:18
