vitbar192 ®   09-Jun-2020 10:51
Ted Brewer Explains Sailboat Design
Year: 1985
Author: Brewer T.
Publisher: International Marine Publishing Co
ISBN: 0-87742-193-5
Pages count: 231
Description: Yacht design is the graceful and artistic merging of science and art into a single, pleasing form. With a keen eye for aesthetics and an engineer’s crisp emphasis on precision, Ted Brewer guides you into the designer’s world.
Throughout the pages of this text you are put into the designer’s shoes and asked to consider, at each critical point, which of the many possible design choices are most in keeping with your ultimate objective. Ted Brewer keeps you ever mindful of the necessary balance between art and science. Achieving that balance is'the designer’s greatest skill and talent.
Beginning with a detailed look at the language of yacht design, you’ll move quickly into a complete discussion of hull shapes; keels and rudders; bows, sterns, and sheerlines; rigs and rigging; engines; interiors; decks; and construction techniques. There is an interesting chapter on how you can deal more efficiently with the designer in planning your own sailboat, and an enlightening discussion of motorsailers. A very complete glossary and bibliography round out the treatment.
Reading this book will remove much of the mystery surrounding the designer’s work. You will be better able to understand your own desires and wishes, and you will be able to translate those wishes into your own boat whether it’s a good stock boat or a custom design.
Brewer E.S. Ted Brewer Explains Sailboat Design, 1985.pdf
USS Salem CA-139 - Steve. Wiper [2000, PDF]
How to sail around the world - advice and ideas for voyaging under sail - Roth H. [2004, PDF]
Paracord Fusion Ties – Vol.1 - Straps, Slip Knots, Falls, Bars, and Bundles - Lenzen J.D. [2012, EPU...
Eco-design of Marine Infrastructures: Towards Ecologically-informed Coastal and Ocean Development - ...
Maritime Electrical Installations And Diesel Electric Propulsion - Alf Kare Adnanes [2003, PDF]
Boat Mechanical Systems Handbook (How to Design, Install, and Recognize Proper Systems in Boats) - D...
Marine Rudders and Control Surfaces - Anthony F. Molland, Stephen R. Turnock [2007, PDF]
Guide for the Environmental Protection Notations for Vessels - ABS [2022, PDF]
Muckle’s Naval Architecture - By W. Muckle and D A Taylor [2013, PDF]
An Introduction to Fluid Mechanics - Faith A. Morrison [2013, PDF]
The time now is: Today 10:08
