gillnumil ®   18-Aug-2018 20:45
Casualty Investigation Code
Year: 2008
Author: IMO
Genre: Convention (rules)
Publisher: IMO
Edition: 1st
ISBN: 9789280114980
Pages count: 32
Description: The MSC adopted a new Code of the International Standards and Recommended Practices for a Safety Investigation into a Marine Casualty or Marine Incident (Casualty Investigation Code) in May 2008. Relevant amendments to SOLAS Chapter XI-1 were also adopted, to make parts I and II of the Code mandatory from 1 January 2010. Part III of the Code contains related guidance and explanatory material.
Additional info: Electronic Edition
Arcan   19-Aug-2018 06:35
gillnumil, BTW - FULL PACKAGE IMO RESOLUTIONS including MSC 255(84) is here.
Next time, please, do not repeat publications, otherwise it will be removed from tracker.
4
POLAR Code (The International Code for Ships Operating in Polar Waters) - KS Gill [2016, PDF]
International Code for Fire Safety Systems (FSS CODE) - IMO [2007, PDF]
Marine Casualty Investigation Investigators’ In-The-Field Job Aid - MAIIF/IMO [201?, PDF]
IMSBC Code - Circ.462(101) - IMO [2019, PDF]
MAIIF Investigation Manual - MAIIF [2014, PDF]
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2020,…
ISM Code and guidelines on implementation of ISM (Electronic Edition) - IMO [2010, PDF]
SOLAS - Amendments to the IMDG Code (Amendment 36-12) In May 2012 the IMO Maritime Safety - IMO…
Instructions for the Guidance of Surveyors on Intact Stability IMO 2008 IS CODE - MCA [2020, PDF]
  • Topic closed
The time now is: Today 16:49
