Arcan ®   07-Apr-2018 18:18
Thrane & Thrane - BGAN-Explorer-510 User Manual
Year: 2015
Author: Thrane & Thrane A/S
Publisher: Thrane & Thrane A/S
Pages count: 111
Description: The EXPLORER 510 is the smallest EXPLORER BGAN terminal ever and is the ideal combination
of performance and portability. It provides simultaneous high quality voice and broadband
access at speeds up to 464 kbps.
The durable magnesium casing and a dust and water resistant design makes the EXPLORER 510
the perfect choice when working off the beaten track but still dependent on a reliable
connection.
Your equipment connects to the EXPLORER 510 with wireless LAN (WLAN).
WLAN is the primary connection between your equipment and the EXPLORER 510. However, a
USB interface is also available, with possible connection of LAN using a USB to LAN Converter
Cable (included).
The EXPLORER 510 provides access to up to 464 kbps Standard data and 32, 64 and 128 kbps
Streaming data and may be used for:
• Broadcasting
• Internet browsing
• E-mail
• Phone services (using WLAN or LAN)
• File transfers
• Video conference and Streaming
• VPN (Virtual Private Network) access to corporate servers
The EXPLORER 510 can withstand severe environmental conditions such as humidity, dust,
extreme weather and changing temperatures. It is small in size and fits easily into a backpack
or similar.
Features
 Full duplex, single or multi-user, standard data up to 464 kbps
 Support for streaming data at 32, 64 and 128 kbps
 Standard WLAN and USB Host interface
 LAN connection using USB to LAN Converter Cable
 Support for EXPLORER Cellular Modem for connection to cellular network
 Built-in battery
 Built-in DHCP/NAT wireless router
 Solar panel direct interface
 10-32 VDC input
 100-240 VAC power adapter
 IP66 protection
 Support for GPS, GLONASS and BeiDou navigation systems
 Support for the EXPLORER Connect app, which makes it easy to use your smart device to
make calls over BGAN, and to set up the EXPLORER 510.
 Built-in web interface allowing you to manage your calls and customize the terminal to your
specific needs, using a smartphone, computer or tablet.
 Point-to-Point Protocol over Ethernet (PPPoE)
 Built-in PBX and SIP server managing voice communication
 Multilingual user interface (English, French, German, Russian, Spanish, Chinese, Japanese)
 CE, FCC, GMPCS and IC certified
Thrane & Thrane - BGAN-Explorer-710 User Manual - Thrane & Thrane A/S [2015, PDF]
Thrane & Thrane - BGAN-Explorer-325 Installation and User Manuals - Thrane & Thrane A/S [2015, PDF]
Thrane & Thrane - Sailor FleetOne Installation and User manuals - Thrane & Thrane A/S [2015, PDF]
Thrane & Thrane - BGAN-Explorer-727 Installation and User Manuals - Thrane & Thrane A/S [2015, PDF]
SAILOR 500/250 FleetBroadband User manual Including 19” Rack Version - Thrane & Thrane A/S [2018,…
Thrane & Thrane - Sailor FleetBroadband-250/500 Installation and User manuals - Thrane & Thrane A/S…
Thrane & Thrane - Sailor FleetBroadband-150 Installation and User manuals - Thrane & Thrane A/S…
Thrane & Thrane - Sailor-6222 VHF DSC Installation and User manuals - Thrane & Thrane A/S [2016,…
Thrane & Thrane - Sailor- 6300 MF/HF DSC Installation and User manuals - Thrane & Thrane A/S [2015,…
The time now is: Today 13:22
