maungmaung ®   19-Dec-2017 21:26
CE ORAL NOTES
Year: 2010
Version: 1
Year: 2012
Author: Kywe Nyein
Format: DOCX
Pages: 122
Description: A NICE BOOK FOR MEO EXAMS.
Additional info: A COLLECTION OF NOTES FOR MEO EXAM.
MARPOL 18
What is MARPOL? 18
MARPOL Certificates: 18
What are MARPOL documents ? 18
What are the MARPOL 73/78 Annexes? 18
What is MARPOL 73/78 Annex IV and explain regulation ? 18
What is MARPOL 73/78 ANNEX VI ? 18
ANNEX 6 18
Regarding ANNEX 6, Which components and settings will be affected the NOX produced by the engine? 19
According to MARPOL regulation , How to discharge oily bilge to overboard ? 19
Regulation 13( For Nitrogen oxide ) 19
Regulation 14 ( For Sulphur oxide ) 20
In accordance with MARPOL Annex VI , Regulation 14 and 18 , do you know the main concern ? 20
What is MARPOL Annex VI , Regulation 18 ? ( or ) 20
SOLAS: 20
What are SOLAS and MARPOL certificates ? 20
What are SOLAS regulation for Inert Gas system ? 20
Oil Record Book 20
What is Oil Record Book ? 20
Oil Record Book: ( Part I ) , For All Ship. 20
Oil Record Book: ( Part II ) , For Oil Tanker. 21
In the Oil Record Book , What mean Code ( Letter ) C , Item ( Number ) 11 ? 21
When that amendment been enforced ? 21
In the Oil Record Book , What mean Code ( Letter ) I ? 21
What should be recorded in code ( Letter ) I ? 21
What are they attached with Oil Record Book? 21
Sludge Tank 22
What requirement of sludge tank ? 22
Sludge Tank Capacity requirements 22
Black Smoke & Air Pollution: 22
How much limitation for emission the black smoke ? 22
Fossil Fuel: 22
What is the air pollution occur which not fossil fuel ? 22
What are serious air pollution causes occur due to fossil fuel? 22
SOPEP: 22
What is the SOPEP ? What are SOPEP equipments ? 22
The plan shall consist at least of: 23
SOPEP Requirements: 23
Garbage: 23
What are garbage and explain garbage regulation ? 23
Sewage: 24
How to discharge overboard sewage from ship ? ( Sewage regulation ) 24
How to operate Biological Sewage Treatment Plant ? 24
What is Biochemical Oxygen Demand, BOD ? 24
What is Coliform Count ? 24
What is DP ? 24
Class & Survey 25
Who is underwritten surveyor? 25
What is classification societies ? 25
IMO: 25
What are IMO conventions ? 25
I.S.M 25
As per your company’s I.S.M standard , How would you done deficiency ? ( Example : such as starting failure of emergency generator due to starter batteries damage ) 25
Statutory: 25
What is Statutory Survey ? 25
What are Statutory Certificates ? 25
Classification: 26
What is classification Survey ? 26
Why Classification Societies sometimes issue the Statutory Certificate? 26
Difference between : Statutory Survey and Classification Survey: 26
Documents: 26
Documents on board: 26
Survey Type: 27
What are periodical survey ( or ) Annual , Intermediate and Special survey ? 27
Periodical Survey: 27
Annual Survey (machinery): 27
Intermediate Survey (machinery): 27
Special Surveys (machinery): 27
Tail Shaft Survey: 27
Explain tail shaft survey ? 27
Tail shaft survey include 27
How to with draw tail shaft ? 28
Flaf State & Port State: 28
What is Flag State ? 28
What is Port State ? 28
How to prepare Port State Control? ( Before entering port ) 28
CMS @CSM: 28
What is CMS ? 28
What items are covered by CMS ? 29
What items are not covered by CMS ? 29
PMS: 29
How to make planned maintenance? 29
Kinds of P.M.S? 29
What is PMS ? 29
What advantages of PMS ? 30
Certificates: 30
What are the certificates onboard? 30
IOPP: 30
What is IOPP and what contain ? 30
How to prepare the IOPP Survey ? 30
How to check IOPP certificate when C/E sign on ? 31
Machinery Survey: 31
How do you prepare machinery survey ? ( M/E or G/E ) 31
Boiler Survey: 31
What is Boiler Survey? 31
Survey interval: 31
Survey items : 31
Annual Boiler Survey includes: 31
At 4 years interval: 32
Preparation for Boiler Survey: 32
Air Bottle Survey: 32
What is the Air bottle survey ? 32
For Tankers / Gas Carrier: 32
Electrical Survey: 32
How to prepare electrical survey? 32
Data to be given to Surveyor for Electrical Survey: 33
How will you prepare for Alternator survey? 33
Alternator Survey: 33
What are the preparations for switchboard surveys? 33
Switchboard Survey: 33
Switchboard Survey, what documents to give to Surveyor? 33
Emergency Power and Associated Equipment Survey: 34
Insulation Resistance Survey: 34
Navigation light indicator survey: 34
Load Line Survey: 34
What is load line survey ? 34
Preparation for Load Line / Annual Survey: 34
Safety Equipment Survey: 35
How to prepare Safety Equipment Survey ? 35
To prepare under care of Chief Engineer . 35
Interim: 35
What is Interim Certificate of Class ? 35
Confirmatory Survey: 35
What is Confirmatory Survey? 35
Safety Construction Survey: 36
What is safety construction survey ? 36
Itemized Survey: 36
How to itemized the survey ? 36
P&I Club: 36
What is P & I Club?(Protection and Identify Club) 36
What is P&I club and purpose? 36
Protecting: 36
Indemnity: 36
As a CE 37
What actions to be taken by C/E when M/E breakdown, fire / explosion occurred ? 37
How do report as C/E damage report form ? 37
As a C/E, How do you hand over / take over duty ? 37
What are C/E’s Routine Works ? 37
What are C/E reports ? 38
Responsibility of C/E: 38
What are C/E duty at Maiden Voyage? 38
Deck Crane: 38
As a C/E , What will you do deck crane is break down ? 38
How to prepare Deck cranes before arrival ? 38
For electrical system and safety devices: 39
For hydraulic system and safety devices: 39
For mechanical system and safety devices: 39
What is crash stop ? 39
Your ship already have been grounded and now clear What will you do ? 39
Bad Fuel: 39
When you received bad fuel , what will you do ? 39
How to test L.O low pressure ? 40
Engine cannot start why ? ( What are engine starting difficult ? ) 40
Enclosed Space: 40
What is enclosed space? 40
How to prepare entry into enclosed space ? 40
If the enclose space is not oil tank or other . 41
Enging Problems: 41
What is First start arrangement ? 41
When do you Hanging-up an engine unit ? 41
Hanging-up procedure: (Mitsubishi UEC 52 HA) 41
What do you take action ? 42
Action taken by CE when ME breakdown ,fire or explosion occurs? 42
In the event of grounding, what action will you do? 42
After a major fire has been extinguished, Explain re-entry procedure to ER.( In case of major fire/ when CO2 flooding carried out) 42
How to take out upper half of cross head bearing shell? 42
Using chain block for remove, for takeout upper shell, set/stop screw remove first. 43
Dry Docking: 43
How to prepare Dry Docking ? 43
During Docking: 43
Undocking: 43
After Leaving the Dock. 44
What do you know from docking plan? 44
UMS: 44
What are UMS safety requirements ? 44
Safety requirement of UMS can be grouped: 44
For UMS operation: 45
Damage report: 45
CE damage report form? 45
Criteria for Detention: 45
Criteria for detention of ship? 45
Main criteria, 45
Application of main criteria; 45
Inspector access whether the ship and /or crew is able to: 45
General Engineering Knowledge 46
Pumps: 46
Why Centrifugal Pump is used in JCW system? 46
Cold Work & Cold Wether: 46
What is cold flow meter? 46
What is cold work permit? 46
How to prepare cold weather protection ? 46
Corrosion, Erosion & Abrasion: 46
What is Hot corrosion ? 46
What is Cold corrosion ? 46
Micro Biological: 47
What is Micro biological activity? 47
What is Microbial degradation ? 47
Microbial Degradation of oil? 47
How to test microbial infection? 47
What is microbial degradation of distillate fuel? 47
Heat Exchanger: 47
How do you precaution carried out plate type heat exchanger cleaning ? 47
What are advantage of plate type heat exchanger ? 47
Purpose of baffle plate? 47
F.O & L.O 48
What factor affect on the ignition? 48
F.O Specification: 48
Do you know what the meaning of FCC ? 48
State one way how to minimize the effect of FCC in your bunker fuel ? 48
What is Viscosity ? 48
What is Viscosity index ? 48
What is Pour point ? 48
What is Flush point ? 48
What is ignition quality ? 48
What is Cetane number ? 48
What is Calorific value ? 48
What cause of high cetane nos.? 48
What cause of low cetane nos.? 48
What is Specific gravity ? What is relative density ? 49
It is weight of given volume of an oil compared to the weight of same volume of F.W expressed as ratio. 49
What is C.C.R? 49
What is Cat fine? 49
L.O Sample: 49
Why L.O sample sent to shore lab ? 49
Where do you take L.O sample for analysis ? 49
How do you carried out L.O onboard test ? 49
Viscosity determination: 49
Three Tubes Rolling Ball Viscometer: 49
Insoluble Content: 49
Blotter Test: 49
Water and other contaminants by: 50
Lubrication: 50
Difference in Cylinder oil and System oil: 50
Filling LO to Sump: 50
What are the function of lubrication ? 50
How many type of lubrication ? 50
What are cylinder oil properties ? 50
How to check correct amount of lubricator feeding? 51
Action when increase L.O level of ME? 51
Type of Oil: 51
Advantages of Synthetics oil? (first class) 51
Mineral oil 51
Paraffinic base oil; 51
L.O Contamination: 51
How to occur L.O contamination with F.W and S.W ? 51
Batch purification is recommended method : 51
If LO is contaminated with SW: 52
Water in LO 52
TBN & TAN: 52
What is TBN ? 52
What is TAN ? 52
FWG 52
Causes of low vacuum effect in FWG? 52
What will happen while vacuum reach 100%? 52
How many type of generating F.W plant? 52
How to remove bacteria? 53
How to remove Chlorine? 53
Maintenance of F.W storage tank 53
What are the sounding pipe requirements? 53
Compressor & Air Bottle 53
Why inter cooler fitted in air compressor ? 53
Volumetric Efficiency: 53
Why Multistage Air Compressor is built? 53
Why air compressor need minimum and absolute lubrication in cylinder ? 53
What are requirements of air bottle ? 54
Air Bottle 54
Class 1 welding regulation 54
Mountings: 54
Internal surface coating: 54
What Safety devices are fitted on Main Air Bottle ? 54
Why LP Relief Valve opening ? 54
Why HP Relief Valve opening? 54
What is Free Air Delivery, FAD? 54
How do you check compressor efficiency during running? 55
How to maintain air compressor efficiency? 55
O.M.D 55
How many type of O.M.D? 55
Which type is used in medium speed engine/ Crosshead type engine. What different between these two types? 55
Oil Mist Detector: ( Function/ Purpose) 55
Type: 55
For calibration: 55
For zero calibration: 55
Checking Sensitivity: 55
How to carried out regular maintenance for oil mist detector ? 55
Inert Gas System 56
Inert gas system safety (alarm)? 56
Advantages of rotary vane type over ram type? 56
Refrigerants & Air Condition: 56
What is Primary Refrigerants? 56
What are the primary refrigerant properties ? 56
What is Secondary Refrigerant? 56
What is “ Critical temperature “ ? 56
How to Defrosting refrigeration Systems ? 56
Why LP Cut-off fitted? 57
What are advantage and disadvantage of brine cooling system ? 57
Why Equalizing Connection is fitted? 57
What is short circling ? 57
How to detect the refrigeration plant condenser tube leakage ? 57
TEV: 57
What purpose of Thermostatic Expansion Valve ? ( TEV function ) 57
Difference between the TEV and solenoid valve ? 57
ICCP & Hull Production. 58
How do you know hull corrosion protection ? 58
What is Cathodic protection? 58
Sacrificial anode system: 58
What is electrochemical corrosion and how to occur ? 58
Bunker 58
Due to sub-standard quality bunker fuel, as a CE what records should be kept? 58
BDN ? ( Bunker Delivery Note) ( Bunker specification)? 59
How to order bunker ? 59
Explain bunker sample taking method? 59
Label must be contain:_ 59
How long should you keep BDN ( Bunker Delivery Note ) ?/ Why ? 59
C/E’s Responsibility during Bunkering: 59
Responsibilities are: 59
Fire Prevention: 60
Pollution Prevention: 60
For Calculations: 60
Bunker Barge Arrival: 60
Bunkering: 60
After Bunkering: 60
F.O overflow while Bunkering: (Action taken by C/E) 61
Boiler 61
What is boiler? 61
What are the causes of boiler corrosion ? 61
What is stress corrosion in boiler ? 61
How to know water level in the boiler ? 61
How to maintain level indicator or level probe sensor ? 61
Boiler Furnace: 61
Causes of furnace distortion? 61
What is Furnace Blowback ? 62
Boiler Feed Tank: 62
What is the purpose of boiler feed tank? 62
Why steam pipe is insulated? 62
Boiler Contamination & Failure: 62
How do you know fuel oil contamination in the boiler water ? 62
How do you carried out fuel oil seen in boiler water ? 62
How to Occur boiler tubes leakage( or) failure ? 62
Boiler Tubes Leakage: 62
How to carried out boiler tubes leakage test ? 62
In the water tube boiler , 62
In the fire tube boiler , 62
How to rectified boiler tube leakage ? ( Procedure ) 63
How to prevent the boiler tube failure ? 63
Boiler Safety Valve: 63
How to set the boiler safety valve ? 63
How to set Accumulation of Pressure ? 63
What are difference between safety valve and relief valve? 63
Safety Valve on EGE and Economizer: 64
Boiler & EGE Safety Devices: 64
What Safety devices are fitted on Boiler ? 64
EGE: 64
EGE out of order: 64
Exhaust Gas Boiler Safety Valve setting: 64
EGE steam pressure controls: 64
Safety device on EGE? 64
Boiler Open_up Procedure: 65
Explain Boiler Open-up Procedure ? 65
Boiler Water Test: 65
Why boiler water test carried out? 65
Why boiler water treatment carried out? 65
What Boiler Water Test should be carried out regularly ? 65
Steering Gear: 65
Explain Steering Gear regulation ? 65
What Safety devices are fitted on Steering Gear ? 66
What are purpose of buffer spring ? 66
Welding: 66
How will you do Welding on Cast iron ? 66
Oxy-acetylene Welding: 66
Arc Welding: 66
What is electron beam welding ? 66
What instruction do you as a C/E of vessel pay attention regarding Welding Equipment handling? 66
Deck Machinery & Safety Devices 67
How do you adjust winch brake? 67
What are they winch safety devices? 67
What are windlass requirements ? 67
What are Windlass safety devices ? 67
What is anchor safety devices ? 67
What is bow stopper ? 67
What are Winch Safety Devices ? 67
Lifeboat safety devices: 67
What Safety devices are fitted on Main Air Compressor ? 68
Safety devices on Exhaust gas boiler : 68
Safety devices on Fudge Plant and Compressor: 68
Fire: 68
Method of extinguishing fires? 68
What is L.E.L and H.E.L ? 68
Fire Control Plan: 68
What is Fire control plan and what contain ? 68
What is fire control plan?/ G.A Plan? 69
Uptake Fire: 69
How to occur the uptake fire ? 69
Other effect are : 69
How to detect uptake fire ? 69
How to prevent the up take fire ? 69
How to Fight the uptake fire: 69
When small inconsiderable Soot Fire occurs: 69
When big considerable soot fire occurs: 70
Fire in Exhaust Trunk: 70
How to occur Exhaust trunk explosion / Fire ? 70
Scavenge Fire: 70
How to occur the scavenge fire ? 70
How to detect Scavenge fire ? 70
How to fire the Scavenge fire ? 71
If fire is not too great: 71
If fire is too great: 71
Precaution: 71
After fire has been extinguished: 71
How to prevent the Scavenge fire ? 71
Starting Air Line Explosion: 71
How to occur Start Air Line Explosion ? 71
Explain Causes of Starting air line explosion ? 71
How to prevent the starting air line explosion ? 72
Main Causes: 72
Preventive measures: 72
What safety devices fitted starting air line ? 72
Crankcase Explosion: 72
Why crank case explosion occur ? 72
Primary Explosion: 72
Secondary Explosion: 72
How to prevent crank case explosion ? 72
How as a CE prevents Crankcase Explosion? 73
Hot Spot: 73
How to happen hot spot ? 73
How to detect hot spot in the crank case ? 73
Crankcase Relief Door: 73
What are requirement of crank case relief door ? 73
SOLAS Regulation and Requirements: 73
How would you test crank case relief valve ? 73
Hydrogen Fire: 73
Why hydrogen fire occur where occur ? 73
Fire Detector: 74
What is fire detector? How many type? 74
Can you explain 4 type of fire detectors fitted on board ? 74
Smoke detector: 74
Heat detector: 74
Flame Detector: 74
Combustible detector: 74
Explain one type of heat detector principle? 74
Fire Pump 74
What are Fire Pumps requirements ? 74
What are Emergency fire pump requirements ? 75
Emergency Fire Pump Regulation: 75
Fire Pump Minimum Pressure: 75
Two pumps simultaneously delivering through nozzles; 75
Regulation for Portable fire extinguishers : 75
CO2 76
How to arrange CO2 room safety system? 76
How do you carried out regular maintenance of CO2 flooding system ? 76
What are CO2 Fix Installation Requirements ? 76
How to calculate require amount of CO2 discharge ? 76
Fire Fighting 77
How do you fight Cargo hold fire ? 77
Fire fighting, for tanker: 77
Paint Locker: 77
How to protect fire from paint locker? Which type of fire detector is used in paint locker? 77
Paint Locker 77
Sprinkler System 77
What are sprinkler system requirements ? 77
What are advantages of sprinkler system? 77
Fire Mam Outfit: 77
Fire man outfit? 77
International Shore Connection: 78
International Discharge Connection: 78
What is standard discharge connection ? 78
M.E.K 78
What is “After running?” 78
What Safety devices are normally fitted on M/E ? 78
Indicator Cards 78
Explain early injection ? 78
Explain late injection ? 79
Before taken indicator card, explain about preparation? 79
What is Ignition Delay ? 79
How do you under stand (1) Atomizing (2) Penetration (3) Turbulence of flow ? 79
High Pressure Pipe 79
What purpose of double wall pipes are used on high pressure line ? 79
How to know fuel high pressure pipe failure ? 79
Piston 80
What causes may occur piston damage ? 80
What causes may occur piston seizure ? 80
Purpose of Skirt? 80
Advantages of super long stroke engines? 80
How to occur blow pass 4 stroke and 2 stroke ? 80
VIT & Fuel Valve. 80
What is VIT ? 80
How to know fuel pump timing is correct or not? 80
What are Fuel Injection Valve requirements ? 81
Cylinder Liner & Lubrication. 81
What are causes of Cracks on cylinder liner ? 81
When you will change liner? 81
How to know cylinder oil consumption ? 81
Specific Cylinder Lubricating Oil Consumption: 81
What may effect excess cylinder lubrication ? 81
Why timed lubrication is very difficult to obtain ? ( Why timed lubrication is little merits ? ) 82
What causes are cylinder liner wear ? 82
Normal frictional wear: 82
Abrasive wear: 82
Corrosive wear: 82
Other related causes: 82
How to maintain minimum cylinder liner wear ? 82
Where is maximum wear ? Why ? 82
Reasons of maximum wear at top of the stroke 82
Where place is thicker place of liner ? 82
What is Scuffing ? 82
Starting Air Valve. 83
Start air system maintenance? 83
How to operate the starting air valve ? 83
Function of automatic valve in air starting system? 83
Exhaust Valve 83
Do you explain Exhaust valve burning ? 83
Exhaust valve defect? Indication? 83
Shock and by-pass valve 83
Chain 83
Can you explain Chain inspection ? 83
What limit of elongation should be tighten the chain? 84
Slack chain: 84
How to adjust chain tension ? 84
Advantages of Chain Drive over Gear Train: 84
Chock: 84
What function of Foundation Chock ? 84
Advantages of Eposy Resin Chock. 85
Engine Speed 85
What is Critical Speed ? 85
What is Economy Speed ? 85
What is Barr Speed ? 85
Barred speed range 85
What is Maximum continuous rating ? 85
What is Continuous service rating ? 85
Engine Over Load: 85
How to know Engine overload ? 85
What are the Causes of engine overload ? 85
How to maintain good M/E performance ? 85
What are ship standard spare parts ? 86
Bearing 86
What will you do, in the event of high bearing temperature or oil mist alarm? 86
How many method for bearing clearance measurement ? 86
What may occur excess bearing clearance ? 86
What may occur less bearing clearance ? 87
Causes of thin shell bearing slip out? 87
What advantage of Thin shell bearing ? 87
What causes are occur to bearing damage ? 87
How do you prevent bearing damage ? 87
What associable problems of top end bearing and guide ? 87
Plumber Block & Tunnel Bearing: 87
How to check plumber block at sea? 87
Difference between Plumber block and tunnel bearing? 88
What do you do if intermediate/plumber block bearing temperature is increased? 88
Stern Tube Bearing: 88
How to measure Stern Bearing Wear-down ? 88
How to minimize leakage ? 88
Supercharging, Turbocharging & Scavenging 88
What is Super charging ? 88
What is turbo charging ? 88
What is scavenging ? 88
What is 3 phase of scavenging ? 88
What type of scavenging use under piston effect ? 88
What are loop scavenging requirements ? 88
What are advantage of under piston scavenging ? 88
Constant pressure system: 89
Pulse pressure system: 89
Advantage of constant pressure system 89
Disadvantage of constant pressure system 89
Advantage of purse system 89
Disadvantage of pulse system 89
Turbocharger 89
What is the function of labyrinth seal? 89
Why T/C over run? 89
T/C Washing & Cleaning: 90
How to be done Blower side Washing ? 90
How to be done Turbine side Washing ? 90
How to be done Dry Cleaning ? 90
What are Advantages of Solid Cleaning ? 90
T/C Surging: 90
How do you understand Turbocharger surging ? 90
Why Turbocharger surging occur ? 90
Causes: 91
Can you Explain causes of turbocharger surging ? 91
Static & Dynamic Balance Rotor: 91
What is Static Balance Rotor ? 91
What is the Dynamic Balance Rotor ? 91
In Case of T/C Failure: 91
What will you do in case of T/C failure? 91
Function of T/C: 92
What are Function of Diffuser ? 92
What are Function of Inducer ? 92
What is function of Nozzle ring ? 92
When you will change T/C bearing? 92
Interlocks & Blocking Device 92
Inter lock? 92
Blocking device? 92
Reversing System 92
What are reversing interlocks? 92
How many Methods of reversing ? 92
Lost motion: 93
Why ‘lost motion’ necessary on some engine? 93
Why ‘lost motion’ not necessary on some engine? 93
Slow Turning 93
What is Slow turning? 93
What is Slow Turning ? 93
Marking on safety valve? 93
Governor 93
What is governor ? 93
What is over speed governor ? 94
What is over speed trip of governor ? 94
What is Hydraulic Governors? 94
What is compensation of governor ? 94
What type of governor used on M/E and G/E and why ? 94
What is governor hunting ? 94
What is governor function? 94
What is Isochronous governor? 94
What is variable speed governor? 94
What is over speed governor? 94
Governor Function: 95
What is Droop? 95
What is Sensitivity? 95
What is Stability? 95
What is Governor Effort? 95
What is dead band? 95
Governor Type: 95
What are the four type of governor? 95
In hydraulic governor, what are they cause of governor faults? 95
Combined rotary / reciprocating type 95
Top Bracing 95
What is top bracing of ME? 95
Tie Bolt 96
Tie bolt tightening method (MAN B & W) 96
Function of tie bolts? 96
Bed Plate & Engine Frame 96
How to cross girder is connected to longitudinal girder? 96
Vibration 96
How to occur Ship Vibration ? 96
What is volcam coupling ? Where in use? 96
What is Axial Vibration? 96
Why Vibration Damper fitted on forward? 96
Detuner: 96
How many type of vibration damper ? 96
Crankshaft 96
What Stresses in Crankshaft ? 96
What safety devices are normally fitted on crank shaft ? 97
Why you measure crank shaft deflection ? 97
What causes will occur misalignment ? 97
What causes occur the crank shaft damage ? 97
Thrust Block: 97
What function of thrust block and how to measure clearance ? 97
Propeller: 98
If the propeller were to start getting loose, play on the shaft, how would this be know? 98
How to remove out Propeller ? 98
Stern Tube: 98
Stern tube wear down. 98
Stern tube oil leakage test. 98
How you check Stern tube Sealing in Dry dock? 98
What action to he taken when SW leaks into Stern tube oil system? 98
Electrical 98
Main Switch Board 98
Switch board survey? What documents to give to surveyor? 98
4 kinds of switch board? 98
What are four type of Switch board ? 98
How to operate Over load trip ? 99
What is Equalizing bar? 99
What is power factor? 99
How will you check the frequency of shore power supply? 99
Rotary Converter: 99
What is Rotary converter? 99
Exciter: 99
What is Exciter? 99
What is Excitation? 99
What will you done if Excitation Loss? 99
How do you prevent excitation loss ? 99
Residual Magnetism: 100
What is residual magnetism ? 100
What is Residual Magnetism? 100
Preferential Trip: 100
What is Preferential trip? 100
First tripping at 5 sec: 100
Second tripping at 10 sec: 100
Third tripping at 15 sec: 100
Test for Over Current Trip: 100
Test for Reverse Power Trip: 100
Essential & Non-Essential Load: 100
What is Essential load ? 100
What is non essential load ? 100
A.V.R 100
What is AVR ? 100
How many types of A.V.R? 101
Carbon Pile Regulator: (AVR) 101
Circuit Breaker & Fuse: 101
What are Difference between Circuit Breaker and Fuse ? 101
Circuit breaker: 101
Fuses: 101
Fuse, to order: 101
Single Phasing: 101
What is Single phasing ? 101
Transformer: 102
Transformer (Iron losses) 102
Motor. 102
Common faults in DC Generators and Motors: 102
What are the AC motor starting methods ? 102
What is induction motor ? 102
Maintenance of Motor? 102
How to starting of motor? How many kind of motor starter? 102
What are Difference between Synchronous Motor and Induction Motor ? 102
What are AC motor overload protections? 102
What will you do after Electrical Machine is flooded with SW ? 102
What is Short, open and grounded circuits ? 103
Sparking at Brushes: 103
Overheating: 103
Megger: 103
Why Megger Reading is taken? 103
How Insulation Resistance of a motor is tested? 103
Megger test 103
Slip Ring & Commutator: 103
Explain difference between Slip ring and Commutator ? 103
Slip ring: 103
Commutator: 103
Why AC is popular onboard ship? 103
How many type of rotor ? 104
Lighting & Lamp: 104
Emergency lighting? 104
What is Navigation lights? 104
What is earth lamp and how do you know earth fault in distribution system ? 104
Why earth lamp is fitted on MSB ? 104
What is discharge lamp? 104
What is Galvanometer? 104
How do you carried out Emergency Lights Maintenance ? 104
What are the requirements for Navigation Light panel ? 104
Electronic 104
What is resistor? 104
What is Rheostat? 104
What is rotating diode/ rectifier? 104
Zena diode? 105
Crane: 105
How will you check ER crane before using? 105
Static Electricity in oil tank, Prevention; 105
Em’cy Power 105
What requirement for Emergency Power Sources? 105
Rules for Emergency Power Sources: 105
Passenger Ship: 105
Cargo Ship: 105
What are Essential Services from Emergency Power Source ? 106
What are Emergency Switchboard Distribution ? 106
How do you carried out Emergency Generator and its maintenance ? 106
How do you start Emergency Generator Starting, when Black-out ? 107
Battery: 107
How do you carried out Battery room inspection and maintenance ? 107
Battery, to order: 107
What are Battery Room Safety Arrangement ? 107
ACB: 108
How do you know ACB ( Air Circuit Breaker ) tripped or not / Closed or Open ? 108
Why ACB does not Close on main switch board ? / What causes are not to close the ACB ? 108
Ward Leonard System: 108
Method: 108
How to change speed? 108
How to change direction? 108
NA 108
Tonnage 108
Gross Tonnage: 109
Exempted spaces: 109
Net or Registered Tonnage: 109
Where Tonnage value is used? 109
What is NRT ( Net Tonnage ) ? 109
What are causes of the out of stability ? How to prepare before loading ? 110
Out of stability are : 110
Prepare before loading : 110
Free Board 110
What is free board ? 110
What purpose of free board ? 110
Conditions of Freeboard Assignment: Why it is important? 111
Bulbous Bow 111
What is bulbous bow ? 111
What are the Purpose of bulbous bow ? 111
Bulbous Bow: 111
Bow Thruster: 112
DB Tank: 112
What is Double bottom ? 112
How much double bottom tanks or spaces ? 112
What is DB tank ? 112
Why DB tanks are constructed ? 112
DB tank pressure test: 112
Camber: 112
What is Camber ? 112
What is PPA ( Propelling Power Allowance ) ? 112
Propelling Power Allowance: 112
Rudder: 113
What isUnbalance rudder ? 113
What is Balance rudder ? 113
What is Semi-balance rudder ? 113
Strake: 113
What is shear strake ? 113
What is bilge strake ? 113
What is garboard strake ? 113
Plan: 113
What is sheer plan ? 113
What is shear plan ? 113
What is Docking Plan ? 113
What is GA plan ? 113
Margin Line & Plate: 114
Margin Line 114
Margin Plate 114
Margin Plate: 114
Keel: 114
Keel plate 114
Types of keel: 114
Bar keel: 114
Flat plate keel: 114
What is Duct Keel ? 114
Floor: 114
Rise of floor: (Dead rise) 114
Floor: 114
Solid Floor: 114
Bulkhead: 115
Class A bulkhead: 115
Class B bulkhead: 115
Class C bulkhead: 115
Standard fire test: 115
What is collision bulkhead ? 115
Corrugated bulkhead: 115
Non-watertight bulkhead: 115
Wash bulkhead: 115
After peak bulkhead: 115
Minimum required bulkhead: 115
Functions of bulkhead: 115
Construction of bulkhead: 116
Why Collision Bulkhead kept at L/20 of the ship? 116
Load Line: 116
Purposes: 116
S, Summer Load Line: 116
W, Winter Load line: 117
WNA, Winter North Atlantic Load Line: 117
T, Tropical Load Line: 117
F, Fresh Water Line: 117
TF, Tropical Fresh Water Line: 117
The difference between Timber Load Line and Load Line 117
Deck Line: 117
Tonnage Mark: 117
Panting, Racking, Slamming or Pounding, Hogging, Sagging: 118
Panting: 118
Racking: 118
Slamming or Pounding: 118
Hogging: 118
Sagging: 118
Heel: 118
List: 118
Function of port hole: 118
Stresses: 118
Transverse stresses: 118
Local stresses: 118
Causes: 118
Dynamic forces: 119
Cofferdam: 119
What is Cofferdam? 119
Tank: 119
Wing Tank: 119
Purpose: 119
Deep Tank: 119
Machinery Casing: 119
Water tightness of steel hatch cover: 119
Hose test and chalk test: 119
Bilge radius: 120
Tumble home: 120
Miscellous: 120
Why cooler is installed after filter? 120
What is the coalesce? Its function? 120
What is fretting? 120
Muster list 120
What is heat conduction? 120
What is heat radiation? 120
What is heat flow? 120
How crack detection method are used? 120
How to measure depth of crack? 121
What is fatigue failure? 121
What is entablature? 121
What is EEBD ? 121
How do you adjust belt tension ? 121
What are the hardness properties of material ? 121
What difference between Explosimeler and Davy Safely Lamp? 121
What is Non- Destructive Tests ? 121
What is Destructive Tests? 122
What is latent heat? 122
What is D.P cell? 122
How do you extinguish fire , If engine room fire at dry docking ? 122
CE_oral_compiled_by_Phone_K_N..docx
Download [550 B]
M.O.T First Class Part (B) for Certificate of Chief Engineer ORAL Examination Questions and Answers…
Crude oil tanker "British Kestrel" Machinery operating manual - Worldwide Marine…
The time now is: Today 16:24
