AnatoliyD ®   07-Nov-2017 23:15
GEA Westfalia Mineral oil centrifuge with self-cleaning bowl OSE-5-91-037
Year: 2014
Author: GEA Westfalia
Genre: Instruction
Number of pages: 210
Description: Centrifugal separators - called separators in short - are used
• for the separation of liquid mixtures which consist of two liquids, with simultaneous removal of the solids contained in the liquids.
• for removing (clarifying) solids from a liquid.
The separator is designed
• for a very high bowl speed.
The admissible bowl speed depends on the chemical and physical properties of the product:
- Temperature
- Density of the fluid and solid components.
• for products which contain no corrosive and erosive components.
The aggressiveness of the product influences the careful selection of the bowl material.
Only products conforming to the specifications on the nameplate may be processed.
• in accordance with the method of application of the separator agreed with GEA Westfalia Separator. Refer to the data sheet and contractually agreements.
• in accordance with the admissible utilities (cleaning agents, lubricants, operating liquids etc.) specified in the documentation or on the data sheet.
Index
1.1 Correct usage.....................................................10
1.2 Non-compliance with the intended use..............................11
1.3 Safety markings...................................................12
1.3.1 Safety markings and their meaning.................................13
1.4 Basic operating principles........................................17
1.5 Operations on the separator.......................................18
1.5.1 Demands on the operating and maintenance personnel................18
1.5.2 Spare part requirements...........................................19
1.5.3 Assembly..........................................................19
1.5.4 Electrical installation...........................................22
1.5.5 Before start-up...................................................23
1.5.6 Start-up..........................................................25
1.5.7 Shut-down and “Emergency-Off*.....................................27
1.5.8 Voltage cutoff during operation...................................28
1.5.9 Maintenance and repair............................................29
1.6 Corrosion.........................................................33
1.7 Erosion...........................................................34
1.8 The health hazards involved when handling heavy oils and lube oils ...36
1.8.1 Code of practice and personal protective measures.................36
OSE 5-91 2066-9001-200-IM.pdf
Download [7 KB]
Alfa Laval S966 Separator Instruction Manual - Alfa Laval Tumba AB [2017, PDF]
Nebosh-Hydrocarbon Process Fire Hazards And Controls [2023, MP4]
Chemical Tanker Mamual - Synergy Group [2021, PDF]
Hydraulic Crane PK xxx M , PK x80 M (Operators Manual) - Crane Power [2005, PDF]
Centrifugal Pumps - Johann Friedrich Gülich [2014, PDF]
Lubricants and Hydraulic Fluids - U.S. Army Corps of Engineers [1999, PDF]
Liquefied Gas Handling Principles on Ships and in Terminals 3th Edition - McGUlRE and WHITE [2000,…
The time now is: Today 14:22
