zxc ®   05-Feb-2026 17:10
Marine Technical Documentation Collection – Engines, Boilers, Pumps, Automation & Manuals
Year: 2000s
Language: English, Multilingual
Author: Various
Genre: Instruction Manual
Publisher: Various
Format: PDF, DOC, DWG, EXE, HTML, JPEG, PPT, XLS, Other
Quality: Scanned pages, eBooks
Pages count: 10000+
Description: The collection is a structured set of technical documentation covering shipboard machinery and onboard systems used on sea and river vessels. The materials are intended for marine engineers, electro-technical officers, motormen, service technicians, and maritime students. All documents are organized for practical use during operation, maintenance, troubleshooting, and repair of ship equipment.
The collection includes operational and service manuals for main and auxiliary diesel engines, including both two-stroke and four-stroke engine types from manufacturers such as MAN B&W, RT-flex, MaK, and others. The documentation contains engine start-up and shutdown procedures, operating modes, monitoring parameters, permissible operating limits, troubleshooting instructions, and maintenance procedures.
A separate section covers boiler plants, steam systems, and heat exchange equipment. The manuals include instructions for safe boiler operation, fuel and air regulation, pressure and temperature monitoring, cleaning and blowdown procedures, and scheduled maintenance routines. Steam line diagrams, fuel supply layouts, and auxiliary boiler equipment schematics are also included.
The collection contains extensive documentation for pump systems used onboard. Manuals are provided for fuel pumps, lubrication oil pumps, ballast pumps, fire pumps, sanitary pumps, and cooling water pumps. The documents describe pump construction, operating parameters, installation diagrams, disassembly and assembly procedures, adjustment methods, and replacement of wear components. Documentation for air compressors and air preparation systems is also included.
Materials related to purification and separation systems from manufacturers such as Alfa Laval and similar suppliers are included. These documents describe the operating principles of fuel and lubricating oil separators, adjustment of cleaning cycles, dismantling procedures, maintenance instructions, and common fault diagnostics.
Additional info: Comprehensive set of technical manuals, datasheets, diagrams, and service documentation for marine engines, boilers, pumps, purifiers, fire detection, and automation systems from multiple manufacturers including MAN B&W, RT-flex, MaK, Alfa Laval, ABB, Danfoss, Clorius, IBAK, HATLAPA, and more.
More
The collection also contains documentation for automation and control systems. It includes manuals covering configuration, programming, commissioning, and operation of monitoring systems, sensors, alarm systems, and safety shutdown systems. The documentation provides wiring diagrams, system logic descriptions, control panel operation instructions, and diagnostic procedures.
Electrical documentation is included for shipboard power distribution and control systems. The collection contains wiring diagrams, switchboard layouts, motor control circuits, alarm and monitoring systems, component identification, troubleshooting methods, and repair guidelines. The materials cover equipment from manufacturers such as ABB, Danfoss, Clorius, and others.
Additional manuals cover auxiliary deck and engine room equipment, including fire detection and firefighting systems, valves, heat exchangers, and hydraulic systems. The documents include service procedures, adjustment methods, operational testing instructions, and safety requirements for working with high-pressure and high-temperature systems.
The documentation is provided in the form of service manuals, operating manuals, spare parts catalogs, technical descriptions, and electrical schematics. The materials are suitable for performing routine maintenance, fault diagnosis, overhaul work, and technical training for maritime personnel.
  • Main engines manuals, operational procedures, and troubleshooting guides
  • Auxiliary machinery instructions, including generators, pumps, and compressors
  • Boilers, heat exchangers, and related equipment operation and maintenance
  • Electrical systems schematics, wiring diagrams, and component datasheets
  • Hydraulic systems diagrams, valves, and pump manuals
  • Automation and control system manuals, programming and commissioning guides
  • Navigation equipment manuals and operational instructions
  • Safety procedures, fire prevention, and emergency protocols
  • Lifeboats, safety equipment, and lifesaving appliances operation guides
  • Technical bulletins, manufacturer updates, and best practices
  • Datasheets, technical specifications, and spare part references
  • Engine overhauls, maintenance schedules, and inspection checklists
  • Sensor integration, calibration, and monitoring systems
  • Electrical and automation troubleshooting and diagnostic guides
  • Classic and rare machinery manuals for older vessel models
  • Training materials for marine engineering students and onboard personnel
  • Practical tips and operational recommendations for efficiency and safety
MARINE_TEH_DOCS
Download [652 KB]
VFR Marine — Electro / Electronic Catalogue for the Shipping Industry - VFR Marine Service [2026, PD...
Practical Centrifugal Pumps - Paresh Girdhar, Octo Moniz [2005, DjVu]
Machinery Operating Manual – Rita Maersk - Maersk [1995, PDF]
A course in: «FRAMO» Hydraulic Cargo Pumping System Course v.1.0 - IMTC [2014, PDF]
Modern Marine Engineer’s Manual Volume 1 - Everett C. Hunt [2010, PDF]
Modern Marine Engineer’s Manual Volume 2 - Everett C. Hunt [2002, EPUB/PDF/AZW]
Ship Repairing English - Zhu Xinhe [19XX, PDF]
Marine Engineering Study Guides - marinediesels.co.uk [2007, PDF]
Electro Technical Officers (ETO) Q&A - Marine Republic [2020, PDF]
The time now is: Today 22:15
