NNT ®   01-Apr-2015 09:19
Centrifugal Pumps
Year: 2014
Author: Johann Friedrich Gülich
Genre: Technical book
Publisher: Springer-Verlag Berlin Heidelberg
Edition: 3rd
ISBN: 978-3-642-40114-5
Pages count: 1146
Description: This book gives an unparalleled, up-to-date, in-depth treatment of all kinds of flow phenomena encountered in centrifugal pumps including the complex interactions of fluid flow with vibrations and wear of materials. The scope includes all aspects of hydraulic design, 3D-flow phenomena and partload operation, cavitation, numerical flow calculations, hydraulic forces, pressure pulsations, noise, pump vibrations (notably bearing housing vibration diagnostics and remedies), pipe vibrations, pump characteristics and pump operation, design of intake structures, the effects of highly viscous flows, pumping of gas-liquid mixtures, hydraulic transport of solids, fatigue damage to impellers or diffusers, material selection under the aspects of fatigue, corrosion, erosion-corrosion or hydro-abrasive wear, pump selection, and hydraulic quality criteria. As a novelty, the 3rd ed. brings a fully analytical design method for radial impellers, which eliminates the arbitrary choices inherent to former design procedures. The discussions of vibrations, noise, unsteady flow phenomena, stability, hydraulic excitation forces and cavitation have been significantly enhanced.
To ease the use of the information, the methods and procedures for the various calculations and failure diagnostics discussed in the text are gathered in about 150 pages of tables which may be considered as almost unique in the open literature. The text focuses on practical application in the industry and is free of mathematical or theoretical ballast. In order to find viable solutions in practice, the physical mechanisms involved should be thoroughly understood. The book is focused on fostering this understanding which will benefit the pump engineer in industry as well as academia and students.
Centrifugal_Pumps-3rdEd-2014
Download [19 KB]
Centrifugal Pumps - Johann Friedrich Gülich [2020, PDF]
Centrifugal Pump Handbook - Sulzer Pumps Ltd. [2010, PDF]
Troubleshooting Centrifugal Pumps and their systems - Ron Palgrave [2019, PDF]
Underwater Structures: The Strength of Submarines and Deep-Diving Submersibles - Piero Caridis…
Water Waves and Ship Hydrodynamics: An Introduction - A. J. Hermans [2011, PDF]
The Centrifugal Pumps - Grundfos [2012, PDF]
GEA Westfalia Mineral oil centrifuge with self-cleaning bowl OSE-5-91-037 - GEA Westfalia [2014,…
Added Masses of Ship Structures - Alexandr I. Korotkin [2008, PDF]
Dynamics of offshore structures - James F. Wilson [2003, PDF]
Ship Resistance and Flow - Lars Larsson & Hoyte C. Raven [2010, PDF]
The time now is: Today 16:00
