Arcan ®   31-Mar-2017 14:34
VoiSea
Year: 2017
Version: 2.1.0
Developer: SKYBRIDGE
Platform: Android
System Requirements: Android 4.0+
Localization: english / russian
Crack: Not needed
Description: VoiSea is the most advanced free HD Voice calling application and messenger that have been designed to work at sea,
in planes or remote locations, through congested 2G/EDGE networks and narrow bandwidth satellite links.
VoiSea - бесплатное HDVoice приложение и мессенджер, который был сконструирован так, чтобы работал везде:
от 2G / EDGE до слабых Wi-Fi и спутниковых сетей.
More Info EN
• Our unique “Low bandwidth” mode allows you to use the application on board cruise, ferries, ships and planes; generally where bandwidth constraints exist. The application needs just 7kbps.
• Bypass VoIP blocking mode to make calls in a country with VoIP restriction policies.
• Calling other phones? Take advantage of our VoiSea-out service with the lowest calling rates in the industry.
• Travelling abroad? Use our Call Forwarding feature and all incoming calls will be free of charge.
Many other features such as:
• Free HD Audio Calls even under 2G/EDGE or very limited bandwidth environments.
• Free lightning-fast instant messaging.
• Cool stickers to make your chats fun.
• Fast photo and location sharing.
• Full support for our left-handed users.
• Highest security and privacy with 2048 RSA encryption.
• Very light on resources, your battery will last up to 1.5 times longer.
• Recognizes local numbers and country codes for your contacts.
What's new:
— New user interface
— Smoother user experience
— Low data usage is now even better
— Bandwidth consumption of recent calls. See exactly how much bandwidth you are using for your recent calls
— Boosted performance
— File Transfer. Share just about any type of file directly on the app
— Redesigned and new emoticons
— Indonesian and Filipino languages support
— Audio calls quality Improvements and bug fixes
Больше инфо RU
Компания «Skybridge» представила новый цифровой голосовой сервис для моряков, который сможет прийти на замену привычным спутниковым каналам связи на судне. Так, приложение «VoiSea» было разработано для бесплатного обмена сообщениями, звонками и видео-записями высокого качества между членами экипажей. Программа обеспечивает быстрый доступ ко всем своим сервисам, при этом сохраняя минимальный уровень потребления пропускной способности.
Приложение устанавливается на мобильный телефон и работает через сеть Wi-Fi, установленную на борту. «VoiSea» позволит морякам использовать приложения с высокой пропускной способностью, когда судно будет находиться в зоне действия широкополосных сетей, и обмениваться сообщениями в зонах действия узкополосных сетей.
– «VoiSea» был разработан специально для моряков. Мы принимали во внимание конкретные проблемы, с которыми сталкиваются экипажи и владельцы судов при работе с ограниченной пропускной способностью сетей на борту, – сказал президент «Skybridge» Константин Симеомидис. – Кроме того эта система может использоваться пассажирами на круизных лайнерах и паромах.
Для моряков «VoiSea» станет недорогой альтернативой роумингу. Приложение сможет работать даже в том случае, если сеть Wi-Fi будет перегружена. Аккаунты пользователей могут использоваться на разных судах, так что если моряк поменяет судно после очередного рейса, у него сохранятся все созданные ранее контакты и истории переписки. Кроме того, «VoiSea» дает возможность за небольшую плату осуществлять звонки на телефоны, не подключенные к приложению. Для этого пользователям нужно будет приобрести кредит через App Store или Google Play.
Простые факты о VoiSea:
• Режим низкой пропускной способности для использования в медленных или дорогостоящих спутниковых сетей.
• Обход VoIP режим блокировки, чтобы совершать звонки в стране с политикой ограничения в Интернет.
• Бесплатные звонки HD Audio даже в 2G / EDGE.
• Свободное молниеносный обмен мгновенными сообщениями.
• Прохладный наклейки, чтобы сделать чатов удовольствие.
• Быстрое фото и геоданных.
• Полная поддержка наших левшей.
• Самый высокий уровень безопасности и конфиденциальности с 2048 RSA шифрования.
• Очень легкий на ресурсы, ваша батарея будет длиться дольше Шифрование до 1,5 раз.
• признает местные номера и коды стран для контактов.
• Бесплатные входящие звонки в то время как за рубежом с нашей переадресации вызовов.
• Почти нет подключения к Интернету? Просто используйте VoiSea обратный вызов.
• Вызов других телефонов? Воспользуйтесь нашим сервисом VoiSea-с самыми низкими ценами.
Что нового:
— Новый интерфейс пользователя
— Более простое управление
— Улучшено использование низкоскоростных сетей
— Статистика использования траффика
— Повышена производительность
— Передача файлов из программы
— Обновлены смайлы
— Добавлены индонезийский и филипинский языки
— Улучшение аудио вызовов и устранение багов
Screenshots / Скриншоты
VoiSea_2.1.0
ABBYY Lingvo Dictionaries v.4.15.3 - ABBYY [2023] [Android]
Что такое retracker.local?
Навигатор Рыбака v.1.35 - Захарчук Михайло [2017] [Android]
Onship v.2.2.4 - FrontM Ltd [2022] [Android]
Crewmates v.1.7 - M20 Marine Services Pvt Ltd [2022]
Thrane & Thrane - BGAN-Explorer-710 User Manual - Thrane & Thrane A/S [2015, PDF]
Marine Tests v.5.0 by Nirex [2024] [Android]
Marinepedia QB v.1.0 - Sumanjay [2020] [Android]
Мобильная связь для моряков
Sea Sector – Maritime Guide for Sailors v.2.5.0 - Sea Sector Ltd. [2020] [Android]
The time now is: Today 23:21
