Arcan ®   06-Feb-2017 13:50
SailPro
Year: 2013
Version: 1.4.0
Developer: Synthesis3
Platform: Android
System Requirements: Android 2.3+
Description: - NAUTICAL GPS NAVIGATOR
- MARINE WEATHER
- CHAT
- ANCHORING SHARING
- LOG BOOK
- SHIPS TECHNICAL SPECS
- ANCHOR ALARM
- SAIL MAGAZINES
ReadMe EN
A shared sea is much safer and shared experiences are much moreintense. This is the philosophy of Social Sailing that enhancesthis nautical GPS able to provide chat connections with sailingcrews world over to share experiences.
SailPro simultaneously indicates your route while showing the otherships sailing in nearby waters, making it possible to chat with theother crews; you can also share photos and comments of the mostbeautiful harbours. Consult WikiSailing at any time for the mostcomplete archive of technical information on all models of sailingships.
The SailPro marine Navigator uses your smartphone’s GPS signal topin-point the location of your ship on the map and calculate allthe other on-screen indications.
- Route plotting
- Compass route
- Relative velocity
- Distance to destination
- Estimated time of arrival
- harbours and ports selectable on the map
- Estimated route calculation (distance between two points on themap)
- On-map route tracking
SailPro is an extremely easy and intuitive marine navigator: thecentral image spins so that the ship’s bow is always aligned withthe point of destination.
PROFILE (social sailing)
Register your profile on SailPro for access to all of the featuresthat social sailing has to offer.. Share your seafaring passionwith other crews. Whether you’re an amateur or simple ship handonboard a large yacht or meager kayak there is no difference atall. We have all taken to the sea for one same reason: to livestrong emotions and the zest of that endless blue that always keepsus going.
CHAT (social sailing)
There just might be other crews available for chat while you’re outin the open seas or docked at any given port. Maybe you just wantto send a quick greeting, exchange weather conditions or providesafety indications. SailPro notifies you of crews available forchat by indicating the other ships on a graphic map. You’ll neverfeel lonely again at sea. Simply deactivate the geolocalizationfeature to enjoy your privacy.
Chat offers a messaging tool for users geolocalized on the map at acustomizable distance from your ship, allowing you to send chatrequests and save preferred contacts.
ANCHORING SHARING (social sailing)
You are anchored in an exquisite harbour that calls for a snap,comment and share your picture with other seafarers; or checkSailPro getting back to land for the closest harbours reported byother users and see pictures, comments and other information.
Enjoy all the advantages of social sailing by sharing yourexperiences with other sailors.
LOG BOOK (social sailing)
Save all of your routes and photos to share them withfriends.
SHIPS TECHNICAL SPECS (WikiSailing)
Check WikiSailing whenever you want fir the most extensive archiveof technical information on all models of sailing ships. Quicklyconsult the technical specs of any model that has caught your eye,along with pictures of ship exteriors and interiors.
ReadMe RU
Море более безопасно, если ты не один. Если поделиться своими впечатлениями с другими, они станут еще значительнее - в этом вся философия социального мореплавания. Именно в этом ценность морского GPS-навигатора, позволяющего общаться с любым экипажем мира и обмениваться индивидуальным опытом.
Указывая путь, SailPro показывает на карте другие суда, курсирующие поблизости, позволяя общаться в чате с другими экипажами. Вы также можете обмениваться фотографиями и комментариями о самых интересных рейдах. В любой момент можно просмотреть WikiSailing («Wiki-Мореход») –самый полный архив технических данных обо всех моделях парусных судов.
МОРСКОЙ GPS-НАВИГАТОР
Навигатор SailPro использует GPS-сигнал вашего смартфона для указания позиции судна на карте и расчета всех других данных, отображаемых на дисплее.
- Прокладка курса
- Управление по компасу
- Скорость относительно земли
- Расстояние до конечного пункта
- Расчетное время прибытия
- Выбранные рейды и порты назначения на карте
- Расчет курса (расстояние между двумя пунктами на карте)
- Отслеживание пройденного маршрута на карте
SailPro – поистине простой и интуитивно понятный навигатор. Центральное изображение поворачивается так, чтобы носовая часть судна всегда была направлена на пункт назначения.
ПРОФИЛЬ (социальная навигация)
Зарегистрируйте профиль на SailPro, чтобы воспользоваться всеми функциями социальной навигации и разделить с другими экипажами свою страсть к морю. Судовладелец или простой моряк, шикарная яхта или спортивный каяк – разницы нет: мы все в море по одной и той же причине - из любви к ощущениям, которые дарит море. Все мы живем этой синевой волн, от которой невозможно устать.
ЧАТ (социальная навигация)
Возможно, во время вашего плавания или рейда на якоре недалеко есть другие экипажи, с которыми можно обменяться по чату простым приветствием, информацией о погодных условиях, а также соображениями по безопасности. SailPro сообщает о местонахождении других судов на графической карте, поэтому при желании вы никогда не почувствуете одиночества в море. Если же вы предпочитаете конфиденциальность, достаточно отключить функцию определения местонахождения, и никто не сможет вас потревожить.
Чат дает вам возможность обмениваться сообщениями с пользователями, находящимися на заданном расстоянии от вас. Вы можете отправить запрос о начале беседы и сохранить нужные контакты.
ВПЕЧАТЛЕНИЯ (социальная навигация)
В интересном рейде снимайте фото, комментируйте и общайтесь с другими мореходами. При приближении к суше проверьте с помощью навигатора SailPro ближайшие рейды других пользователей с фотографиями, комментариями и другой информацией.
Воспользуйтесь всеми преимуществами социальной навигации, обмениваясь опытом с другими мореплавателями.
БОРТОВОЙ ЖУРНАЛ (социальная навигация)
Вы можете сохранить все свои рейды и фотографии и поделиться ими с друзьями.
СХЕМЫ СУДОВ (WikiSailing)
В любой момент Вы можете обратиться к WikiSailing – самому обширному архиву технических данных обо всех моделях парусных судов. Вы можете сразу узнать подробные сведения об интересующем Вас судне и просмотреть фото, в том числе внутреннего устройства.
Click Me / Тыц
Download [5 KB]
MarineTraffic v.4.0.46 - MarineTraffic [2023] [Android]
MarineTraffic Mod Apk Latest Update v.3.9.56 - Marine Traffic [2020] [Android]
Sea Sector – Maritime Guide for Sailors v.2.5.0 - Sea Sector Ltd. [2020] [Android]
Практическая навигация для современных яхт и катеров - Пэт Мэнли [2009, PDF]
TransOcean - The Shipping Company [2014]
ShipAtlas v.5.0 - Maritime Optima AS [2024] [Android]
Marine Navigation v.4.0.5 - Marco Palaferri [2017] [Android]
VoiSea v.2.1.0 - SKYBRIDGE [2017] [Android]
Навигатор Рыбака v.1.35 - Захарчук Михайло [2017] [Android]
ABBYY Lingvo Dictionaries v.4.15.3 - ABBYY [2023] [Android]
The time now is: Today 16:55
