zxc ®   23-Jul-2013 20:37
Технология очистки в сепараторах GEA Westfalia / GEA Westfalia Separator - Separation Technology
Country: Germany
Duration: 03:07
Translation: no
Description: GEA Westfalia Separator - Separation Technology
Separator with bowl, drive,feed and diicharqe.The tepjrstion procesi tskes place in the rotor.A large clarification area In comparison to sedimentation by gravity.Is realized by conical discs and high g forces.Ribs beneath the distributor accelcratc the product.The product it fed Into the rising channels and iplit up over a large number of disk interspaces.Due to the higher dtmity the tolldt ttream aogoimt the conical diio...
Video info
Video
Format : VP6
Duration : 3mn 7s
Bit rate : 857 Kbps
Width : 386 pixels
Height : 308 pixels
Display aspect ratio : 5:4
Frame rate : 25.000 fps
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Duration : 3mn 7s
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
GEA Westfalia - SeparationTechnology.flv
Download [16 KB]
How to work Westfalia D-Type Separators [2001, AVI]
GEA Westfalia Mineral oil centrifuge with self-cleaning bowl OSE-5-91-037 - GEA Westfalia [2014, PDF...
MAN B&W - L+V 28/32 - Removal and Overhaul of cover, piston and liner [199x, MP4]
Serck Fresh water Generator Type PTE25-20-85 - Serck Como GmbH [2005, DOC]
Dismantling of Alfa Laval S-Type (Video) [MPG]
Standard safety - tankers - The Standard Club [2016, PDF]
POSOW - Oiled wildlife response - POSOW [2013, PDF]
The time now is: Today 11:19
