ehab22brakotta ®   20-Aug-2016 00:35
SCHOTTEL BOW TUNNEL THRUSTER TYPE STT 2 CP
Year: 2007
Author: SCHOTTEL
Description: Nominal input power: 735 kW‎
Nominal input speed: 1470 r.p.m.‎
Gear reduction: 3,727: 1‎
Propeller diameter: 1550 mm‎
Propeller material: GS-CuAl10Fe5Ni5-C
Number of blades: 4‎
Manufacturing standard: ISO 484/2-1981 (E). Tolerance Class II‎
Direction of rotation looking at input shaft of thruster: clockwise
Delivered tunnel length: 2000 mm‎
Wall thickness of tunnel: 20 mm‎
SCHOTTEL_BOW_TUNNEL_THRUSTER_TYPE_STT_2_CP.pdf
Helicon X3 P&T Control System User Manual - Rolls-Royce [2014, PDF]
Полный архив судовой документации парома Ro-Ro Eglantine [2006, PDF/XLS/DOC]
PropCAD v.10 - Hydrocomp [2010]
Samyung SES-5000 Echo Sounder User Manual - Samyung ENC [2015, PDF]
NMF SWL700T board crane instruction manual - Neuenfelder Maschinenfabrik GmbH [2009, PDF]
SC ALMAR
Marine Propellers and Propulsion Third Edition - J S Carlton FREng [2012, PDF]
Marine Propellers and Propulsion (Second Edition) - J. S. Carlton [2007, PDF]
The time now is: Today 15:18
