twicer ®   20-Sep-2021 21:51
Guide for Wind Assisted Propulsion Поржал System Installation
Year: 2021
Author: ABS
Pages count: 29
Description: This Guide is applicable to two modern wind assisted propulsion technologies: Flettner
rotors and wing sails (including rigid sails and soft sails). These technologies use the wind thrust generation
and automatic control system to optimize thrust force generation based on wind conditions.
These systems differentiate themselves from conventional sails in that they possess greater efficiency,
smaller windage area, and automatic control systems.
These technologies are continuously evolving. Alternative arrangements, designs and technologies may be
acceptable on a case-by-case basis, provided they can be demonstrated, through either satisfactory service
experience or a systematic evaluation based on sound engineering principles, to meet the overall
requirements of this Guide.
Wind Asisted Propulsion Guide_2021.pdf
Guide for wind assisted Propulsion System Installation - ABS [2020, PDF]
Guide for Air Lubrication System Installation - ABS [2018, PDF]
GUIDE FOR USE OF LITHIUM BATTERIES IN THE MARINE AND OFFSHORE INDUSTRIES - ABS [2018, PDF]
Study and analysis of the use of wind power for the propulsion of merchant vessels. Case study. -…
Guide for Bridge Design and Navigational Equipment and Systems - ABS [2022, PDF]
Guidelines for ships using Low-Flashpoint Fuels (Methyl/Ethyl Alcohol / LPG) - NKK [2019, PDF]
Modern Ship Engineering, Design and Operations - Reusser C. [2021, PDF]
Guidelines on Ammonia Fueled Vessels - Indian Register of Shipping [2022, PDF]
Guide for Bridge Design and Navigational Equipment/Systems - ABS [2019, PDF]
MAN Service experience - MAN B&W [2019, PDF]
The time now is: Today 17:09
