virtual ®   26-May-2020 09:57
Guide for wind assisted Propulsion System Installation
Year: 2020
Author: ABS
Pages count: 24
Description: This Guide is applicable to two modern wind assisted propulsion technologies: Flettner rotors and wing sails (including rigid sails and soft sails). These technologies use the wind thrust generation and automatic control system to optimize thrust force generation based on wind conditions. These systems differentiate themselves from conventional sails in that they possess greater efficiency, smaller windage area, and automatic control systems.
wind-assisted-propulsion-guide-jun20.pdf
Download [1 KB]
Guide for Wind Assisted Propulsion System Installation - ABS [2021, PDF]
Study and analysis of the use of wind power for the propulsion of merchant vessels. Case study. - Da...
NavCad 2009, PropCad 2005, PropExpert 2005 - HydroComp Inc. [2005/2009]
Guidelines wind assisted propulsion systems for ships.pdf - ClassNK [2023, PDF]
Wind Assisted propulsion Systems for ships - ClassNK [2024, PDF]
Wing Sail Performance Compared to a Traditional Sail on Sailing Craft - Turner H. [2015, PDF]
Assessment Of Selected Alternative Fuels And Technologies - DNV GL [2019, PDF]
Wind Propulsion Systems: Rule Note NR 206 DT R01 E - Bureau Veritas [2021, PDF]
Guide for Bridge Design and Navigational Equipment/Systems - ABS [2019, PDF]
Guide for Bridge Design and Navigational Equipment and Systems - ABS [2022, PDF]
The time now is: Today 07:59
