virtual ®   12-Oct-2018 20:09
Guide for Air Lubrication System Installation
Year: 2018
Author: ABS
Pages count: 12
Description: This Guide is applicable to three air lubrication technologies: air bubble, air layer and air cavity methods,
which are currently in various degrees of development by the industry. These technologies are continuously
evolving. Alternative arrangements, designs and technologies may be acceptable on a case-by-case basis
provided they can be demonstrated, through either satisfactory service experience or a systematic analysis
based on sound engineering principles, to meet the overall requirements of this Guide.
The effective date of this Guide is the first day of the month of publication.
air-lubrication-guide-oct18.pdf
Download [526 B]
Guide for Wind Assisted Propulsion System Installation - ABS [2021, PDF]
GUIDE FOR USE OF LITHIUM BATTERIES IN THE MARINE AND OFFSHORE INDUSTRIES - ABS [2018, PDF]
Air Lubricated and Air Cavity Ships: Development, Design, and Application - Pavlov G.A., Liang Y.,…
Rules for buliding and classing Floating Production Installations (FPIs) - ABS [2020, PDF]
Guidelines for ships using Low-Flashpoint Fuels (Methyl/Ethyl Alcohol / LPG) - NKK [2019, PDF]
MAN Service experience - MAN B&W [2019, PDF]
Guidelines on Ammonia Fueled Vessels - Indian Register of Shipping [2022, PDF]
Requirements for Application of Higher-Strength Hull Structural Thick Steel Plates in Container…
Guidance Notes on Life Extension Methodology For Floating Production Installations - ABS [2021, PDF]
The time now is: Today 15:10
