mmhkhang ®   01-Jul-2021 11:44
Furuno Operator's Manual Echo Sounder Model LS-4100, LS-6100
Year: 2002
Author: FURUNO
Publisher: FURUNO
Pages count: 49+48
Description: The FURUNO LS-6100 is a dual frequency (50 kHz, 200 kHz) monochrome LCD echo
sounder. Comprised of a display unit and a transducer, the LS-6100 displays underwater conditions on a bright 6-inch monochrome LCD.
The main features of the LS-6100 are
• Compact design permits installation where space is limited.
• Bright 6-inch monochrome LCD gives excellent readability even in broad daylight.
• Wide variety of display modes: single frequency, dual frequency, bottom-lock, marker-zoom, bottom-zoom, and nav data.
• Automatic function permits unattended adjustment of range and gain. The range scale and gain automatically change to display the bottom in the darkest gray tone on the lower half of the screen.
• User-programmable nav data displays provide analog and digital nav data.
• Alarms: Bottom, Fish (bottom-lock and normal), Speed, Water Temperature and Arrival. (Speed and arrival alarms require appropriate sensor; water temperature alarm requires water temperature data.)
• A-scope display helps discern echo amplitude.
• White line feature helps discriminate fish lying near the bottom.
• Destination waypoint feature provides range, bearing, and time-to-go to destination waypoint.
• Waterproof construction permits installation on open bridge.
Furuno Navigational Echo Sounder FE-700 - Furuno [2000, PDF]
JRC Echo Sounder Instruction Manual JFE-380 - JRC [2012, PDF]
JRC Echo Sounder Instruction Manual JFE-680 - JRC [2012, PDF]
Furuno Operator's manual navigational Echo Sounder Model FE-800 - Furuno [2014, PDF]
Furuno Echo Sounder FE-800 - Furuno [2014, PDF]
Furuno Dual GPS GP-90-DUAL - Furuno [2003, PDF]
JRC Marine Radar Instruction Manual JMA-5300 Series - JRC [2013, PDF]
Furuno Color Instrument FI-70 Operators Manual - Furuno [2016, PDF]
Samyung SDF-310 Standalone Digital Fishfinder User Manual - Samyung ENC [2014, PDF]
JRC Marine Radar Instruction Manual JMA-3300 Series - JRC [2011, PDF]
The time now is: Today 05:27
