twicer ®   06-May-2021 12:30
Instructions for the Guidance of Surveyors on International Load Line
Year: 2020
Author: MCA
Pages count: 155
Description: INSTRUCTIONS FOR THE GUIDANCE OF SURVEYORS ON INTERNATIONAL LOAD LINE Rev 05.2020
Based on the IMO LOAD LINES 2005 CONSOLIDATED EDITION AS AMENDED
The International Convention on Load Lines, 1966 (1966 LL Convention) was adopted on April 5, 1966 and entered into force on July 21, 1968. Ships built prior to that date were covered by the 1930 Load Line Convention. The 1966 LL Convention was modified by the 1988 Protocol which was adopted on November 11, 1988 and entered into force on February 3, 2000
The 1988 LL protocol was itself modified by the 2003 Amendments which were adopted by IMO Resolution MSC.143(77) on June 5, 2003 and entered into force on January 1, 2005.
International_Load_Line MSIS41_R05.20.pdf
zino16   29-Jan-2024 19:48
many thanks for sharing documents for more information using our experience
Load Lines Convention 2021 Edition - IMO [2021, PDF]
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2023, PD...
Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (BCH Code) - I...
FAL Convention - IMO [2017, PDF]
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2020, PD...
MODU CODE 2009 (CODE for the Construction and Equipment of Mobile Offshore Drilling Units) - IMO [20...
COLREG - IMO [2004, PDF]
Instructions for the Guidance of Surveyors on International Load Line - MCA [2023, PDF]
Clean Seas Guide for Oil Tankers - OCIMF [1994, PDF]
MARPOL Consolidated Edition - IMO [2011, PDF]
The time now is: Today 12:44
