twicer ®   04-May-2021 21:20
Maneuvering in Shallow and Confined Water
Year: 2017
Author: Marc Vantorre, Katrien Eloot
Pages count: 18
Description: The maneuvering characteristics are highly affected by the under‐keel clearance. In shallow water, the results of standard maneuvers reveal a decreased maneuverability and an increased straight‐line stability.
This modified behavior is mainly to be ascribed to the modified flow around the hull, but also the control forces exerted by rudder and propeller are different compared to the deep‐water case. Besides the effect of vertical limitations, a ship navigating parallel to the horizontal boundaries of navigation areas will also experience the so‐called bank effects, that is, disturbing forces and moments due to the asymmetry of the flow around the hull.
Maneuvering in Shallow and Confined Water.pdf
Hydrodynamic Interaction and Squat (In-House Training) - Thome Shipmanagement [2017, PDF]
Handling with Large Ships and Ships with unusual manoeuvring characteristics - Ship Handling…
Mathematical Modeling of inland vessel Maneuverability considering rudder hydrodynamics - Jialun…
Rudder, Propeller and Hull Interaction by Rans - C. Simonsen [2000, PDF]
Ship Dynamics for Mariners - I. C. Clark [2005, PDF]
Shiphandling for the Mariner - Daniel H. MacElrevey and Daniel E. MacElrevey [2018, PDF]
Canadian Tidal Manual - Forrester W. D. [1983, PDF]
Lectures On Ship Maneouvrability - Nikolai Kornev [2013, PDF]
Simulation Study of the IAMSAR Standard Recovery Maneuvers for the Improvement of Serviceability -…
A Guide to Ship Handling (The best seamanship) - Japan Captains' Association (JCA) [2009, PDF]
The time now is: Today 11:49
