twicer ®   04-May-2021 21:20
Maneuvering in Shallow and Confined Water
Year: 2017
Author: Marc Vantorre, Katrien Eloot
Pages count: 18
Description: The maneuvering characteristics are highly affected by the under‐keel clearance. In shallow water, the results of standard maneuvers reveal a decreased maneuverability and an increased straight‐line stability.
This modified behavior is mainly to be ascribed to the modified flow around the hull, but also the control forces exerted by rudder and propeller are different compared to the deep‐water case. Besides the effect of vertical limitations, a ship navigating parallel to the horizontal boundaries of navigation areas will also experience the so‐called bank effects, that is, disturbing forces and moments due to the asymmetry of the flow around the hull.
Maneuvering in Shallow and Confined Water.pdf
Handling with Large Ships and Ships with unusual manoeuvring characteristics - Ship Handling Researc...
Hydrodynamic Interaction and Squat (In-House Training) - Thome Shipmanagement [2017, PDF]
Mathematical Modeling of inland vessel Maneuverability considering rudder hydrodynamics - Jialun Liu...
TUG Use In Port - 3 Ed - Captain Henk Hensen [2018, PDF]
Rudder, Propeller and Hull Interaction by Rans - C. Simonsen [2000, PDF]
Canadian Tidal Manual - Forrester W. D. [1983, PDF]
Shiphandling for the Mariner - Daniel H. MacElrevey and Daniel E. MacElrevey [2018, PDF]
Simulation Study of the IAMSAR Standard Recovery Maneuvers for the Improvement of Serviceability - M...
Tidal calculator v.0.0.40 - DBG Nautical [2019] [Android]
The Drift Force and Moment on Ships in Waves - J. N. Newman [1967, PDF]
The time now is: Today 12:18
