gillnumil ®   03-Sep-2019 19:11
Guidelines For The Handling, Storage, Inspection And Testing Of Hoses In The Field
Year: 1995
Author: OCIMF
Publisher: Witherby & Co. Ltd.
Edition: 2nd
ISBN: 1856090701
Pages count: 11
Description: At Offshore mooring installations, the hose strings are a critical link between the terminal and tanker. They are constantly subjected to the dynamic forces of the sea which can result in severe loads and stresses within the hose. To provide greater reliability and longer life, it is imperative that the hose be handled and stored correctly and be inspected and tested in a consistent manner at appropriate intervals.
The purpose of these guidelines is to minimize hose damage from handling and storing, so as not to adversely affect operations by hose failure. Compliance with proper inspection and testing procedures will also increase the probability of detecting potential failure areas in a timely manner.
Thus, these recommendations have been prepared to provide the user with a guide to proper handling and storage and a means of determining the condition of hoses in service.
OCIMF Guidelines For The Handling, Storage, Inspection And Testing Of Hoses In The Field 2nd Edition 1995
Download [19 KB]
OCIMF Guidelines for STS hoses - OCIMF [2021, PDF]
Single Point Mooring Maintenance and Operations Guide (SMOG) - OCIMF [2015, PDF]
Guidelines for the Handling, Storage, Use, Maintenance and Testing of STS Hoses - OCIMF [2021, PDF]
Static Towing Assembly Guidelines (STAG) - OCIMF [2020, PDF]
Guide To Purchasing, Manufacturing And Testing Of Loading And Discharge Hoses For Offshore Moorings…
Guidelines For Liquid Chemical Hose Management - Chemical Distribution Istitute (CDI) [2016, PDF]
Recommendations for the Tagging/labelling, testing and Maintainence, Documentation/certification…
A Study into Crane Loads Associated with Hose Handling at Offshore Terminals - OCIMF [2015, PDF]
The Carriage of Methanol in Bulk Onboard Offshore Vessels - OCIMF [2020, PDF]
Guidance on Line Management Plans (LMP) - INTERTANKO [2019, PDF] - INTERTANKO [2019, PDF]
The time now is: Today 18:36
