Ferreirolo ®   16-Jun-2020 13:18
The Carriage of Methanol in Bulk Onboard Offshore Vessels
Year: 2020
Author: OCIMF
Publisher: OCIMF
Edition: 1
Pages count: 50
Description: This best practice document provides a guide for the safe loading, carriage and discharge of methanol by offshore support vessels.
The carriage of methanol in bulk is becoming common in the offshore oil and gas industry, and although there is technical documentation on methanol handling, guidance for offshore carriage by sea is limited.
The supply of bulk methanol to offshore locations is the responsibility of several stakeholders, including the supplier, transporter and user of the product.
Methanol (Methyl Alcohol, CH3OH) is a wood alcohol used in oil and gas production to prevent hydrate formation, which often occurs in gas condensate fields. Injection of methanol into the well downhole zone of gas hydrate fields not only causes decomposition of gas hydrates in that downhole zone of the well but also improves downhole zone filtration characteristics.
Methanol is a hazardous chemical with significant toxic, flammable, and reactive properties that can adversely affect human health and the environment when not properly handled.
Methanol is highly flammable, burns with no visible flame in daylight conditions and is readily miscible in water. Special care should be exercised when loading and discharging this product, and instructions within a vessel’s procedures or marine operation manuals should be followed.
Safety is the biggest consideration when carrying methanol in bulk.
To achieve safe carriage, all bulk methanol cargo should be maintained in an inert condition while onboard offshore support vessels. This should be in line with the IMO OSV Chemical Code which requires an oxygen content of 8% or less and clear areas around pressure/vacuum relief valves (P/V valves) and manifolds.
The assigned product tanks should be protected by cofferdams which should be inerted by means of water or nitrogen.
carriage-of-methanol-in-bulk-onboard-offshore-vessels.pdf
Inert gas systems - The use of inert gas for the carriage of flammable oil cargoes (First edition)…
Code of Practice 6, The Safe Distribution of Acetylene in the Pressure Range 0 - 1.5 BAR, Revision…
Code Of Practice 5, The Design and Construction of Manifolds using Acetylene Gas from 1.5 to 25…
Inert gas systems: The use of inert gas for the carriage of flammable oil cargoes - Oil Companies…
Liquefied Gas Handling Principles on Ships and in Terminals 3th Edition - McGUlRE and WHITE [2000,…
(BLCH) Guide , Bulk Liquid Chemical Handling Guide for Plants, Terminals, Storage and Distribution…
Guidelines For The Handling, Storage, Inspection And Testing Of Hoses In The Field - OCIMF [1995,…
Cargo pumps and related systems in M/T - ΣΑΡΑΦΟΠΟΥΛΟΥ ΑΓΓΕΛΙΚΗ [2018, PDF]
Rules of Russian Maritime Register of Shipping - RMRS [2018, PDF]
The time now is: Today 16:07
