twicer ®   06-Sep-2021 21:16
A Study into Crane Loads Associated with Hose Handling at Offshore Terminals
Year: 2015
Author: OCIMF
Genre: Research papers
Pages count: 39
Description: Current industry recommendations for the lifting capacities of hose handling cranes are contained in the OCIMF’s Recommendations for Oil Tanker Manifolds and Associated Equipment (an update of which is due in 2015). However, the published guidance does not specifically take account of the potentially increased weight of floating hose strings resulting from the above factors.
This paper is a summary of the findings and recommendations from the study. The substance of the report is included as an annex and full copies of the report, including further detailed appendices, are available from the OCIMF secretariat on request.
OCIMFCRANE.pdf
Download [1 KB]
Static Towing Assembly Guidelines (STAG) - OCIMF [2020, PDF]
Recommendations for Oil and Chemical Tanker Manifolds - Oil Companies International Marine Forum…
Guidelines For The Handling, Storage, Inspection And Testing Of Hoses In The Field - OCIMF [1995,…
OCIMF Guidelines for STS hoses - OCIMF [2021, PDF]
The OCIMF Human Factors Approach - OCIMF [2020, PDF]
OCIMF - Transfer of Personnel by Crane between Vessels - Ocimf [2018, PDF]
Virtual Arrival Optimising Voyage Management and Reducing Vessel Emissions - an Emissions…
Guidelines for the Control of Drugs and Alcohol in the Maritime Industry - OCIMF [2024, PDF]
Single Point Mooring Maintenance and Operations Guide (SMOG) - OCIMF [2015, PDF]
Transfer of Personnel by Crane between Vessels - Oil Companies International Marine Forum [2018,…
The time now is: Today 15:06
