Arcan ®   02-Dec-2016 19:25
Navi-sailor 3000. VirtualBox Workstation with Win 10(En) x86 + WF61
Year: 2006
Version: 4.00.07
Developer: Transas
Platform: All Windows x32, x64, Linux
Windows7 compatibility: yes
System Requirements: VirtualBox installed, RAM for virtual engine at least 1.5 Gb and 15 Gb space on hard disk (may increase up to 32 Gb)
Description: VirtualBox Workstation with installed Transas Navi-Sailor 3000 and Win 10 (En). Installed charts WF61 (license until Dec, 30, 2013.
Engine configured to slave.
No need to switch date back and start sentemu. All fixed.
VirtualBox works with Windows 7, 8, 10 either x86 , or x64, and also with Linux.
Additional info: 1. Install VirtualBox
2. Create Virtual engine (Win 10) with RAM at least 1.5 Gb, and VideoMemory 128 mb
3. Use downloaded file as hard disk.
click me!
VM_Navi_Win10  SILVER RELEASE!
Download [21 KB]
onlinespiderman   06-Dec-2016 11:05
Hello Arcan,
I downloaded your windows 10 virtual box image and i copied it to a physical drive.
It works great on my PC and i am very pleased with it.
i just want to ask you if you can provide the password for the protected settings,...in the system configuration utility.
Thanks alot for this great gift!
Arcan ®   06-Dec-2016 11:28
27086Hello Arcan,
Password is default - transas
onlinespiderman   06-Dec-2016 11:34
27088
27086Hello Arcan,
Thanks alot my friend!!
serdarkontas   14-Dec-2016 21:44
Hello Arcan, i have downloaded and it is working good but i am having problem with mouse on chart csreen mouse is going crazy is there any solution for this.
thanks alot.
Arcan ®   15-Dec-2016 09:02
27302Hello Arcan, i have downloaded and it is working good but i am having problem with mouse on chart csreen mouse is going crazy is there any solution for this.
thanks alot.
Virtualbox engine menu - Input - Mouse integration
To leave this mode - Right Ctrl ( by default)
serdarkontas   15-Dec-2016 15:19
27306
thanks alot.
Hello Arcan, Thank you very much it works great.
onlinespiderman   08-Jan-2017 13:15
Hello Arcan,
Just want to ask if this version will work on a 64bit system?
I heard that there is a x64 bit version of Navi-sailor 3000 available around,...and i thought i should ask you!
Info here:
http://www.morehod.ru/forum/transas/topic9094-1170.html#p677590
Thanks alot!
Arcan ®   09-Jan-2017 11:47
27789Hello Arcan,
Info here:
Thanks alot!
I think it's possible now. See your mail.
onlinespiderman   09-Jan-2017 11:58
27793
27789Hello Arcan,
Info here:
Thanks alot!
Thanks alot for the link,....i got it from kostya72 too!
All the instructions are in Russian,.....I even tried through google translate but alot of words are not translated properly!
Do you think you can use this method on your version,....which also has newer maps and create a virtualbox file with win 10 x64?
Arcan ®   09-Jan-2017 12:45
27795
I send you message in PM. Check mailbox.
With win 7 x64 and with win 10x64 it's will be possible, whenever it will be a good way to awoid check of driver signing enforcement.
All three known ways does not work on both OS.
Arcan ®   10-Jan-2017 18:25
27789Hello Arcan,
Works. On Windows 10 x64 ("Anniversary"). Now tested. BUT WITH TRICKY START.
See HERE
paxtu   10-Jan-2017 23:33
Hi Arcan I have not been able to install, I have win 7 x 64 in a virtual machine for Mac and it does not let me appear the error of the license i.S20002.
Arcan ®   11-Jan-2017 09:38
27857Hi Arcan I have not been able to install, I have win 7 x 64 in a virtual machine for Mac and it does not let me appear the error of the license i.S20002.
What you are talking about?
Arcan ®   11-Jan-2017 18:46
27877Navisailor 3000 ecdis I in win 7x64
With all x64 OS there are problem as driver of emulator either you can't install or if even is installed it does not work and you get this message:
Click here to see
The only one way at this moment exist - to start Windows with "Disable driver signature enforcement" mode:
Click here to see
This mode give you permission to install driver and use it.
Next time write your message in the proper part of forum.
Good luck!
Updated: The problem with driver signature enforcement solved IN THIS TOPIC]
ivan_ice   16-Jan-2017 15:33
Народ не забывайте снять галочку в свойствах файла "только чтение"! Были проблемы с запуском.
Arcan ®   17-Jan-2017 08:54
27975Народ не забывайте снять галочку в свойствах файла "только чтение"! Были проблемы с запуском.
О чём Вы, уважаемый? Ни один файл ни скачанный, ни выложенный файл не имеет в свойствах установленный флаг "только чтение":
тыц
Это, скорее всего, Ваш личный глюк.
hbgffgn43   03-Mar-2017 13:16
Файл vdi не открывается Iso manager'om
Выдает следующую ошибку:
тыц
Transas ECDIS master/slave issue
Chart Planner v.3 [2016]
Steam Engine Room 2 LNG (ULM) v.Free Demo - Unitest [2006]
HMC ECDIS v.5.1 [2014]
TRANSAS WORLD FOLIO NR 74 DEC, 20, 2016 (WF74) v.4 [2016]
TRANSAS WORLD FOLIO NR 75 MAR, 14, 2017 (WF75)
MaxSea v12.6.4.1 + CM93v3 Nov-2019 charts (Windows 10 VirtualBox) - MaxSea [2019]
TRANSAS WORLD FOLIO NR 76 JUNE, 02, 2017 (WF76)
The time now is: Today 03:46
